I have set up everything to run for MRP on the PO side, but when i run the PO suggestions, im no getting anything? Where do I go to see the results ?
Brian
Brian
You will see them in New PO Suggestions program. Eventually in Time Phase.
I still not seeing anything in PO Suggestions, I have bumped all qty to make sure it picks up the demand. but I run MRP and then go to Change PO Suggestions and nothing is showing up. all parts have a 0 on hand and I have cleared out all po’s to make it create new ones
Also, this sounds like you may be prepping for a go-live?
And finally, Introduce yourself when you can…
This may sound like a smug comment… but double check you have your parts set up with the “Generate Suggestions” checkboxes checked.
I was just doing some testing in our 3rd environment, which hasn’t been updated in ages, and after generating suggestions half a dozen times with no suggestions… it hit me to double check my test part and wouldn’t you know it… the part I was using wasn’t set up for it.
One other thing that has tripped me up several times… are you an authorized user on the buyer ID for those suggestions?
