Thanks Babette and also Calvin who emailed.
Problem solved.
Regards
Richard Whalebelly
IT Manager
SHelbourne Reynolds Eng Ltd
Problem solved.
Regards
Richard Whalebelly
IT Manager
--- In vantage@yahoogroups.com, "Babette Welch" <bwelch@...> wrote:
> Michael Podlin assisted us in doing this last year.
> At the Command line for the VBForm button put:
> RUNPROG label_jobWASP.p
> Save the p version at
> V:\mfgsys61\VBP
> (not compiled)
> Here is the code, replace your library and report names:
> {VBP\VB.I}
> /* This is required by Epicor Vantage. */
> /* program written 2/25/05 by Babette Welch, assisrance & template
from Michael Podlin */
> /* associated with button in Job Tracker>VBForm, button code is
RUNPROG VBP\job_label.p */
> /* No compile, text file only */
> DEF VAR ReportLibrary AS CHARACTER INITIAL "V:\mfgsys61
\ud\argo_rpts\Menu.prl". /* This is the Report Builder Library file
and full path */
> DEF VAR ReportName AS CHARACTER INITIAL "label_jobWASP". /* This
is the name of the report you want to run */
> DEF VAR ReportFilter AS CHARACTER INITIAL "". /* This is the
filters to use with the report you want to run */
> DEF VAR ReportMethod AS CHARACTER INITIAL "".
> /* This defines how to handle the report. Entering a "P" will
cause the report to run to the workstations default printer. */
> /* Entering a "D" will call up the report in a preview mode first
on the screen. */
> /* Leaving it blank will cause the following screen to appear on
the workstation and the user can then select the method of running
the report. */
> /* The name of the report will appear in the window title bar and
all available printers will in the the drop down selection list. */
> /* The workstations default printer will be the default choice.*/
> DEF VAR ReportCopies AS INTEGER INITIAL 1. /* This allows you to
select the number of copies to print. Default is one. */
> DEF VAR ReportMessage AS CHARACTER INITIAL "". /* ReportMessage is
used to relay a message to the user. */
> /* Some reports take a long time to run and it may be useful to
notify the user of this and give the user the chance */
> /* to cancel out of running the report. The popup message will
look like the one below. */
> /* It will display the report name and the message you assign to
the ReportMessage variable. */
> /* The "Do you wish to continue?" is automatically added as the
last line of text. Leaving the ReportMessage variable blank will
bypass this message. */
> FIND jobhead WHERE ROWID(jobhead) = GetCurrentRowID() no-lock. /*
Replace "DatabaseTable" with the table name */
> /* that is associated with the VBForm that you will be launching
this from. */
> ASSIGN ReportFilter = "Jobhead.JobNum='" + jobhead.jobnum + "'"
+ "and substring(jobasmbl.partnum,1,5)<>'ester' and substring
(jobasmbl.partnum,1,5)<>'ether' and substring(jobasmbl.partnum,1,3)
<>'ar-'".
> /* You will need to enclose character values in single quote
marks. Numeric values will have to be defined using a STRING
(Table.Integervaluefield). */
> RUN VBP\VBFormRpt.R(ReportLibrary, ReportName, ReportFilter,
ReportMethod, ReportCopies, ReportMessage).
> Babette Welch
> IT Director
> Argonics, Inc.
> 1110 Wright Street
> Marquette MI 49855
> 906.226.9747 ext 235
