Another way is to make two quote forms. One for each plant, and then a
master quote form that is blank except for two footers. Footer A is
Subreport 1 - quote plant A, footer B is Subreport 2 - quote plant B.
On the master quote form, prompt the user with a parameter field for
which plant they need a quote and then suppress the footer section that
isn't needed.
This is a work around for the ceasar development multiform until you get
to version 8 of vantage.
HTH,
Calvin
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Stuart Noble
Sent: Thursday, May 26, 2005 6:39 PM
Subject: [Vantage] Printing Seperate forms
Hi there. We have two separate factories at different addresses. We only
use one Plant location in Vantage, as we saw no need to set up another
plant for a closely linked company. The only problem we are having, is
that when we send a quote out from the secondary factory, the contact
details are for the primary factory. What is the best way to customise
the address, phone number and email to appear for the secondary factory
when required. Do we need to make a second quote form for that factory,
and if so what is the best way to select that second form when it is
required?
Thanks in advance.
Stuart
Yahoo! Groups Links
isn't needed.
HTH,
Calvin
Of Stuart Noble
required?
Thanks in advance.
Stuart
Yahoo! Groups Links
