Good Day:
RE: Problem Solved RE: [epicor-users] E9 9.05: Need Help - PO suggestions are not bein created
Checking the "Generate Po Sugg...." fixed it.
They did not generate because we had unchecked "Engr Release" on the JOB.
We are now getting PO-Suggestions Generated.
Len
Leonard C. Hartka, IT Director\ERP Manager
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@... <blocked::mailto:len.hartka@...>
www.Sunautomation.com <blocked::http://www.sunautomation.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Paul L Bennett
Sent: Friday, July 30, 2010 10:47 AM
Subject: Re: [Vantage] E9 9.05: Need Help - PO suggestions are not being created
Have you set the Min and Max order quantities for the part. I beleive PO
Suggestion looks as this to determine when to generate.
Paul
From: Len Hartka <len.hartka@... <mailto:len.hartka%40sunautomation.com> >
Sent: Fri, July 30, 2010 10:32:55 AM
Subject: [Vantage] E9 9.05: Need Help - PO suggestions are not being created
Good Day:
Sun Is on M2K (Informix) but,
Going to: Epicor 9, 9.05.600B.2 SQL (go live date is 10/4/10)
RE: E9 9.05: Need Help - PO suggestions are not being created
We are in a sort-of-Conference-room-Pilot, we have some"P" parts
that should get PO-Suggestion.
When we run either "Create Sug" or MRP, - we get none.
Parts have "Create PO Sug" checked. or "P" types.
What are we most likely missing?
Len
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
<blocked::mailto:len.hartka@... <mailto:len.hartka%40sunautomation.com> >
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential
information. If you are not the intended recipient, please notify the sender
immediately by reply e-mail or at 410-472-2900 and then delete the message
without using, disseminating, or copying this message or any portion thereof.
With e-mail communications you are urged to protect against viruses.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Len
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
Paul
Good Day:
Len
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
Celebrating
25 Years of Service
