Stu,
This could be from a few things, all relating to an SMTP setting.
1) Check in the .mfgsys file that you are using for the smtpserver
value,
2) The SMTP server name does not allow for relaying OR
3) You misspelled the name. usually a minor typo
Also, if the servername doesn't work for you, you could always try to
put the IP address in it's place.
Of stu horwitz
Sent: Saturday, December 08, 2007 1:29 PM
Subject: [Vantage] problem with e-mail from vista
Has anyone experienced the following?
When trying to e-mail a record from any screen in vista, I get the
message "could not access CDO.Message object". This only occurs on
client workstations. When logged into the server, e-mail works fine.
Epicor support has not come up with a solution yet. Any input would be
appreciated.
Stu Horwitz
Advanced Packaging Inc.
Stu@... <mailto:Stu%40advpack.com>
This e-mail is for the use of the intended recipient(s) only. If you have received this e-mail in error, please notify the sender immediately and then delete it. If you are not the intended recipient, you must not use, disclose or distribute this e-mail without the author's prior permission. We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
value,
Of stu horwitz
appreciated.
Stu Horwitz
