variances can happen for multiple reasons in an average cost world:
transactions happening out of sequence… ie… you receive parts to stock, and then post additional labor/material
you have a PO for $1 each, but then when receiving, you adjust the cost on the receiver, or you adjust the cost on the Invoice to something other than $1.
In a standard cost world… variance happen all teh time. You have an item with a standard cost of $1, but you create a po for $1.5, it will post a variance of $0.50 when you do the receipt.
Epicor introduce the addition variance accounts I believe with 10.2.xxx
If you setup different accounts for Labor, Burden, Material and Subcontract you will find out what is getting transacted into the job’s after the job is received into inventory. This will then be on the general ledger vs just reviewing the inventory COS and WIP reconciliation report for the different transactions.
