just a FYI - there is a Crystal Report Group similar to this Vantage Group here on Yahoo that might be very helpful to several of you struggling with a CRW issue or two. There are some very knowledgeable folks and a few hacks such as myself but you'll soon learn who to listen to. Just a thought.
BILL R. KING
J&B Industrial Services
(806).776.4409 Office
(254).592.4397 Cell
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sean Toler
Sent: Monday, April 05, 2010 1:53 PM
Subject: [Vantage] Re: Production Detail Crystal Report Modifications
I think I sent you a private message, but I'm not sure.
BILL R. KING
(254).592.4397 Cell
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Sean McDaniel" <smcdanie@...> wrote:
> You can't display a shared variable within the same section that it is
> modified. I can't even tell you what results you may or may not get :o)
> What I typically do is add a new section directly below where a shared
> variable is set and put my "display" there.
> You also need to be careful as a section or object that is suppressed will
> not change a shared variable, but a section that is hidden will still set
> the shared variable.
> If you'd like you can send me the report and I can take a quick look for you
> (smcdaniel@...). If you have the XML data file that would be
> a great help so I don't need to try and reproduce one.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> Sean Toler
> Sent: Monday, April 05, 2010 2:16 PM
> Sometimes I feel like the things that I'm asked to make happen whether it be
> in a BAQ, Dashboard, Customization, or in a Crystal Report require a
> four-year degree to understand and figure out!
> Anyway, I'm not sure if you guys utilize the Production Detail Report or
> not, but what I think I've discovered is that the Gross amount variable is
> created in the Invoice Activity SubReport.
> It is then recalled in Group Footer #2s. This footer displays the
> profitability of the current job in the report. If I select a number of jobs
> for the report, this footer is displayed at the end of each report for each
> job.
> But, when I try to recall this same variable in the report footer in an
> attempt to display the grand total for all of the jobs in the report, I've
> been either getting zero, or the gross amount for the last job in the
> selection.
> I haven't been able to come up with a way to get a grand total.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Sean
> McDaniel" <smcdanie@> wrote:
> > You'll need to do something like this in a formula.
> > Then you drag the formula where you want it in your report.
> > Shared NumberVar GrossAmt:=GrossAmt;
> > GrossAmt
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > Sean Toler
> > Sent: Monday, April 05, 2010 1:42 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > OK, I have no idea how to make this work.
> > How can I get the report to give me a grand total in the report footer
> using
> > these shared variables?
> > Everything I try either gives me zeroes or the incorrect amount.
> > Toler" <seantoler@> wrote:
> > > Looks like I have a lot more to learn about Crystal. I haven't had to
> work
> > with variables before.
> > > > This is a shared variable. So, while you are editing the formula, do a
> > > > search for "GrossAmt" and see what comes up. My guess is that there is
> > > > another formula that is something like "GrossAmt := GrossAmt + ."
> > Behalf Of
> > > > Sean Toler
> > > > Sent: Monday, April 05, 2010 10:17 AM
> > > > Subject: [Vantage] Production Detail Crystal Report Modifications
> > > > Hello.
> > > > I've been asked to modify our Production Detail Report so it will give
> a
> > > > grand total of the prices of the products (gross amount, misc.
> charges,
> > net
> > > > amount). I see where this is done on the report for each job, but what
> > we
> > > > want to be able to do is to have a grand total at the end of the
> report
> > when
> > > > the report consists of multiple jobs (the report already does this for
> > the
> > > > costs and hours).
> > > > There is a formula used on the report that brings in the gross amount
> on
> > > > each job, but it is a type of formula that I am not familiar with. I
> > tried
> > > > to do a summary of it, but CR wouldn't let me. The formula is called
> > > > VarGrossAmount and its code is as follows:
> > > > GrossAmt
> > > > Does anyone know if this formula can be modified to give a grand
> total,
> > or
> > > > if a new one can be written that will give me the desired result?
> > > > [Non-text portions of this message have been removed]
The information contained in this message is intended solely for the individual to whom it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the contents of this information, is strictly prohibited.
We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
This message (including any attachments) is intended only for
the use of the individual or entity to which it is addressed and
may contain information that is non-public, proprietary,
privileged, confidential, and exempt from disclosure under
applicable law or may constitute as attorney work product.
that any use, dissemination, distribution, or copying of this
communication is strictly prohibited. If you have received this
communication in error, notify us immediately by telephone and
(i) destroy this message if a facsimile or (ii) delete this message
immediately if this is an electronic communication.
Thank you.
