I'm an Office odbc/SQL junkie - but why would you WANT all your clients to have odbc access?
You are just asking for undesirable performance problems if anyone in the building can start hitting the server with (likely unoptimized) SQL queries via Office apps, etc.,.
If you DO deploy to all, lock it down with password authorization required and HEAVILY limit who has that password!
Rob Brown
Rob Brown
--- On Fri, 5/23/08, Lee Ingalls <eli3@...> wrote:
Subject: RE: [Vantage] Progress database driver
Date: Friday, May 23, 2008, 8:35 AM
Different variations depending on the version but Support has an "ODBC
kit" for OE101B & SQL, v8.03.4xx, they email out upon request.
NOTE: UPON REQUEST.
Includes:
Registry_Entries
Adding ODBC Reports to Menu.doc
ODBCdiagnostics. pdf
ODBCTableList400. txt
SQL92_Guide_ Reference. pdf
SQL_Connect. BAT
SQL_Connect. TXT
V803400_Instruction s.rtf
You can also UNC path to \\servername\ epicor\oe101b\ netsetup but you
will still need the ODBC kit.
Regards,
Lee Ingalls
Commercial Tool Group
____________ _________ _________ _________ _
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of philpott.matt
Sent: Friday, May 23, 2008 4:27 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Progress database driver
Just about to roll out Vantage after weeks of learning, training etc.
but the installation process no longer puts the Progress database
driver onto each PC. Support have come up with nothing. Can anyone
help please?
TIA
