Enclosing a field in double quotes will general protect it from
corrupting the import. Most import functions recognize this a signal
that a character string follows, and ignore any embedded special
characters until the second quote is encountered.
Thad Jacobs wrote:
Specialists in Progress Databases and Software since 1986
William E. Colls william@...
PROComputer Systems Tel 613 591 0079
67 Willow Glen Dr. Fax 613 591 3924
Kanata Ontario Canada www.procomsys.com
K2M 1T1
Thad Jacobs wrote:
> In my experience, having commas in exported fields does not corrupt the file
> (as far as IMPORT Statements, excel, access, or ado jet drivers are
> concerned).
> So depending on the interface you are using to read the file, it may not
> always be necessary to strip commas out of descriptions, however, it's
> probably good practice none the less, especially if you're writing your own
> csv import code.
> Thaddeus
> -----Original Message-----
> From: lonniedrew [mailto:lonniedrew@...]
> Sent: Thursday, March 14, 2002 1:14 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Progress Exports, next step (are we to adolescent
> steps yet?)
> Oops, sorry. Instead of using substring to replace "," with " " in
> orderdtl.linedesc, copy to variable LineDescVar, then use substring
> on new variable. Export LineDescVar, not orderdtl.linedesc.
> Lonnie
> ldrew@...
> --- In vantage@y..., "lonniedrew" <lonniedrew@c...> wrote:
> > Troy,
> > This might work....
> > def var ReleaseRemaining as integer init 0.
> > output to c:\Releases.csv.
> > for each orderdtl break by orderdtl.partnum:
> > for each orderrel where orderrel.company = 0rderdtl.company
> > and orderrel.ordernum = orderdtl.ordernum
> > and orderrel.orderline = orderdtl.orderline
> > break by orderrel.orderrelnum:
> > ReleaseRemaining = ReleaseRemaining + OrderRel.OurRelQty -
> > (OrderRel.OurJobShippedQty + OrderRel.OurStockShippedQty).
> > end.
> > if last-of(orderdtl.partnum) then do:
> > /* get rid of commas in description */
> > repeat while index(orderdtl.linedesc,",") > 0:
> > substring(orderdtl.linedesc,index(orderdtl.linedesc,","),1)
> > end.
> > export delimiter "," orderdtl.partnum orderdtl.linedesc
> > ReleaseRemaining.
> > ReleaseRemaining = 0.
> > end.
> > end.
> > output close.
> > --- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> > > Jim,
> > > I have this report done in Crystal which, as you say, is quite
> > simple. But it is just step one of a two-step report that will use
> > those numbers to input to another report that will list all the
> > subcomponent materials for those assemblies. I know I could do it
> in
> > Crystal as all one report, along with a subreport; but if I could
> > automate the first part with Progress and have it export nightly
> (as
> > we do with some other reports), then the second part would run nice
> > and fast and could be run on demand.
> > > So, I'm looking for a Progress solution for the first part to
> > make the whole thing more automated and quicker.
> > > Troy Funte
> > > Liberty Electronics
> > > ----- Original Message -----
> > > From: Jim Stetter
> > > To: vantage@y...
> > > Sent: Thursday, March 14, 2002 11:35 AM
> > > Subject: RE: [Vantage] Progress Exports, next step (are we to
> > adolescent steps yet?)
> > > Troy, I don't have the answer using Progress but this would be
> > very simple
> > > to do with Crystal and ODBC. From Crystal you can export to
> > Excel. I have
> > > created numerous reports designed specifically for export to
> > Excel and use
> > > Crystal Decision WebComponent for client access. This setup has
> > saved me
> > > tons of aggravation and time.
> > > Jim Stetter
> > > From: Troy Funte [mailto:tfunte@e...]
> > > Sent: Thursday, March 14, 2002 10:50 AM
> > > To: Vantage
> > > Subject: [Vantage] Progress Exports, next step (are we to
> > adolescent steps
> > > yet?)
> > > Many of you have been able to export .csv files directly
> using
> > small
> > > Progress programs. I have done this with straight - record for
> > record
> > > queries by copying and pasting from the Export Utility in
> > Vantage. Next
> > > crossroads I have come to is this:
> > > Is there a way to Group, Summarize and Total fields in an
> > export? Does
> > > anyone have sample code to do that?
> > > Specifically, I want to take the OrderHed, OrderDtl, and
> > OrderRel tables,
> > > Group by PartNum, Find the formula OrderRel.OurRelQty -
> This
> > would be
> > > the BalanceDue.
> > > Then I want to Summarize the BalanceDue for each PartNumber.
> > > Output to the .csv file would only include: PartNum,
> > Description,
> > > BalanceDue.
> > > Any ideas?
> > > Troy
> > > Yahoo! Groups Sponsor
> > > ADVERTISEMENT
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You
> > must have already linked your email address to a yahoo id to enable
> > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services
> goto:
> > http://groups.yahoo.com/group/vantage/links
> > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
K2M 1T1
