Progress Program for Dialog Box
But if they get along then they pass stuff and the more they pass the less free we seem to be... Maybe I'd better stick to Progress 4GL.
Mark, we must continue this over a beer sometime at a future Perspectives conference. Thanks for a badly needed chuckel this afternoon.
NB
--- In vantage@yahoogroups.com, Mark Wonsil <mark_wonsil@...> wrote:
> Nathan wrote after Bernie:
> > "I believe you will have a very diffucult time with this." ...yep - but that dosen't mean it isn't fun to try.
> As fun as getting 435 people in the US Congress to get along... ;-)
Vantage 8.03.408B(s)
Hi,
Looking for a Progress program in the Epicor Library or some custom 4GL code that will give me the option to prompt users for a "YES/NO" or "OK/CANCLE" response as part of an Update Pre-Process.
Anyone have anything like this or some sample code I could start with?
Nathan Bonner
bonner.n@
totalplastics.com
269.553.5838
Nathan,
This is the progress code. I have not tried it in a BPM. If No is
answered it leaves program.
MESSAGE "Ready to begin the XXXXXXXXXX processing?"
VIEW-AS ALERT-BOX QUESTION BUTTONS YES-NO UPDATE ok-beg AS
LOGICAL.
IF not ok-beg THEN DO:
RETURN.
END. /* IF not ok-beg */
Hope this helps.
Dale E. Schuerman
Senior Consultant
Epicor Certified Consulting Partner
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@...
<BLOCKED::blocked::mailto:dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
(website)
Of Nathan
Sent: Friday, January 29, 2010 10:24 AM
Subject: [Vantage] Progress Program for Dialog Box
Hi,
Nathan Bonner
bonner.n@
totalplastics.com
269.553.5838
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Dale,
I am not having much luck getting this to work from within a BPM. Any other thoughts?
NB
--- In vantage@yahoogroups.com, "Dale Schuerman" <dale.schuerman@...> wrote:
> Nathan,
> LOGICAL.
> RETURN.
> Hope this helps.
> Dale E. Schuerman
> Senior Consultant
> 972-669-9603 (fax)
> (website)
> Of Nathan
> Hi,
> Thanks,
> Nathan Bonner
> bonner.n@
> totalplastics.com
> 269.553.5838
> Attention:
> by MailMarshal SMTP
Here's where I am at with this...
BO.Method is Customer.Update.
Script is on a Pre-Process 4GL Action.
Define Variable curr-cust as rowid.
DEFINE FRAME a
ttcustomer.name
WITH 1 DOWN USE-TEXT.
For each ttCustomer exclusive-lock.
Do:
MESSAGE "Update " + ttcustomer.name + "?" VIEW-AS ALERT-BOX
QUESTION BUTTONS YES-NO UPDATE kill-it AS LOGICAL.
IF kill-it = No
THEN DO:
/*still working on the action for condition 'kill-it = No'*/
END.
END.
ENABLE ALL WITH FRAME a.
PAUSE 0 BEFORE-HIDE.
WAIT-FOR WINDOW-CLOSE OF CURRENT-WINDOW.
RELEASE ttCustomer.
END.
This procedure passes Validation without a problem but throws the following 4GL Stop error when run...
Error Detail
4GL STOP condition: The Server application has returned an error. (7243) (7241)
Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Proxy.CustomerImpl.Update(CustomerDataSet ds)
at Epicor.Mfg.UI.Adapters.CustomerAdapter.Update()
at Epicor.Mfg.UI.App.CustomerEntry.Transaction.Update()
The problem seems to be in the "ENABLE ALL WITH FRAME a." as I can turn it on and off by commenting out this line.
Any suggestions?
NB
--- In vantage@yahoogroups.com, "Nathan" <bonner.n@...> wrote:
> Dale,
> Thanks,
> NB
> --- In vantage@yahoogroups.com, "Dale Schuerman" <dale.schuerman@> wrote:
> > Nathan,
> > LOGICAL.
> > RETURN.
> > Hope this helps.
> > Dale E. Schuerman
> > Senior Consultant
> > 972-669-9603 (fax)
> > <BLOCKED::blocked::mailto:dale.schuerman@> (email)
> > (website)
> > Of Nathan
> > Hi,
> > Thanks,
> > Nathan Bonner
> > bonner.n@
> > totalplastics.com
> > 269.553.5838
> > Attention:
> > by MailMarshal SMTP
It seems to me, you are asking for code to be executed on the server (that is where BPMs are processed) and to have that code interact with a client across the network. I believe you will have a very difficult time with this
> DEFINE FRAME a
> ttcustomer.name
> Do:
> IF kill-it = No
> THEN DO:
> END.
> END.
> RELEASE ttCustomer.
> END.
> Error Detail
> Stack Trace
> Any suggestions?
> Thanks,
> NB
> --- In vantage@yahoogroups.com, "Nathan" <bonner.n@> wrote:
> > Dale,
> > Thanks,
> > NB
> > > Nathan,
> > > LOGICAL.
> > > RETURN.
> > > Hope this helps.
> > > Dale E. Schuerman
> > > Senior Consultant
> > > 972-669-9603 (fax)
> > > (website)
> > > Of Nathan
> > > Hi,
> > > Thanks,
> > > Nathan Bonner
> > > bonner.n@
> > > totalplastics.com
> > > 269.553.5838
> > > Attention:
> > > by MailMarshal SMTP
bw2868bond,
NB
> > DEFINE FRAME a
> > ttcustomer.name
> > Do:
> > IF kill-it = No
> > THEN DO:
> > END.
> > END.
> > RELEASE ttCustomer.
> > END.
> > Error Detail
> > Stack Trace
> > Any suggestions?
> > Thanks,
> > NB
> > > Dale,
> > > Thanks,
> > > NB
> > > > Nathan,
> > > > LOGICAL.
> > > > RETURN.
> > > > Hope this helps.
> > > > Dale E. Schuerman
> > > > Senior Consultant
> > > > 972-669-9603 (fax)
> > > > (website)
> > > > Of Nathan
> > > > Hi,
> > > > Thanks,
> > > > Nathan Bonner
> > > > bonner.n@
> > > > totalplastics.com
> > > > 269.553.5838
> > > > Attention:
> > > > by MailMarshal SMTP
