Proper steps to Modify a Crystal report - Add a custom BAQ
Plamen - I'm pretty sure that Epicor broke something in 407 because I
experienced the same issue in 407A.
_____
plamen21
Sent: Friday, January 22, 2010 6:33 AM
Subject: [Vantage] Re: Proper steps to Modify a Crystal report - Add a
custom BAQ
Forgot to mention I am in 8.0.3.407c.
I tried linking via both inner and left outer joins, and in both directions.
Anybody who played with Resource Data Definitions out there?
Plamen
Systems Administrator
Art display Co.
Signs . Awnings .
Architectural Details
www.artdisplayco.com
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Manasa
Reddy" <manasa@...> wrote:
> Try opening up the report and click on the help link...it might have
> some info in there....
> M. Manasa Reddy
> manasa@... <mailto:manasa@...>
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
> Of Dines, Tim
> Sent: Thursday, January 21, 2010 3:02 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: RE: [Vantage] Re: Proper steps to Modify a Crystal report - Add
> a custom BAQ
> I agree. The key is missing and possibly some filtering. This all
> works very well in 8.03.408b, but you can only modify system reports if
> you have the SDK.
> Is there anywhere to get the definitions for reports like the Time
> Phased Material Requirements report that are not listed in the RDD?
> Tim Dines
> Information Technology
> Steel Parts Manufacturing, Inc.
> 801 Berryman Pike
> Tipton, IN 46072
> Direct: 765-675-5201
> Cell: 765-437-1402
<mailto:vantage%40yahoogroups.com> ] On
> Behalf
> Of Manasa Reddy
> Sent: Thursday, January 21, 2010 3:46 PM
> a custom BAQ
> All I am going to say is that if you are on an earlier version than
> 8.03, this is not going to work. That is, adding a table to your RDD.
> If you are at or beyond that version, then the Foreign key is probably
> your problem...make sure you linked the table correctly.
> M. Manasa Reddy
> manasa@... <mailto:manasa%40weldcoa.com>
> <mailto:manasa%40weldcoa.com> <mailto:
> <mailto:manasa%40weldcoa.com> >
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> Behalf
> Of plamen21
> Sent: Thursday, January 21, 2010 2:39 PM
> custom BAQ
> Ok I Duplicated the Report Data Definition, added the table I need
> [CustCnt] and excluded any of the unnecessary fields from that table.
> I am probably missing a step above on the RDD ['foreign key' comes to
> mind not sure why or how].
> Then I set my report to use the new RDD in Report Maintenance, preview
> it once to create the XML, so I can Set Datasource Location in Crystal,
> and so I can use the XML to pull the newly added table into the database
> fields.
> I think I am missing a step in RDD because even the Company Field is
> blank if I try to Browse Data in Crystal. Also the newly added table
> does not have any Indexed Fields (Red arrow) in Database Expert.
> Plamen
> Art Display Co.
> Signs * Awnings *
> 401 Hampton Park Boulevard
> Capitol Heights, MD 20743
> (P) 240-765-1400
> <mailto:vantage%40yahoogroups.com> ,
> "jckinneman" <jckinneman@> wrote:
> > You either need to modify the original report through a Custom Report
> Data Definition or create a new BAQ/Crystal Report. You can't add a
> custom BAQ to an existing crystal report.
> > If you have support there are some examples on-line that explain some
> of the customizations you can do to existing reports. Search for "report
> definition crystal".
> > Jim K.
> > En>compass Solutions Inc.
> > Tel 336.298.1296 (Google Voice)
> > Fax 336.217.7983
> > E-mail jimki@
> > www.encompass-inc.com
> "plamen21" <plamen21@> wrote:
> > > Hello,
> > > I am trying to modify an existing Crystal system report to:
> > > Add the results of a custom query (BAQ) that I created.
> > > I have a just a custom BAQ just for the additional data.
> > > I am looking for the proper procedures (and sequence).
> > > Using Vantage 8.03.407C on Progress
> > > Plamen
> > > Art Display Co.
Hello,
Plamen
Art Display Co.
You either need to modify the original report through a Custom Report Data Definition or create a new BAQ/Crystal Report. You can't add a custom BAQ to an existing crystal report.
If you have support there are some examples on-line that explain some of the customizations you can do to existing reports. Search for "report definition crystal".
Jim K.
Fax 336.217.7983
E-mail jimki@...
--- In vantage@yahoogroups.com, "plamen21" <plamen21@...> wrote:
> Hello,
> Plamen
> Art Display Co.
Ok I Duplicated the Report Data Definition, added the table I need [CustCnt] and excluded any of the unnecessary fields from that table.
I am probably missing a step above on the RDD ['foreign key' comes to mind not sure why or how].
Then I set my report to use the new RDD in Report Maintenance, preview it once to create the XML, so I can Set Datasource Location in Crystal, and so I can use the XML to pull the newly added table into the database fields.
I think I am missing a step in RDD because even the Company Field is blank if I try to Browse Data in Crystal. Also the newly added table does not have any Indexed Fields (Red arrow) in Database Expert.
Plamen
Art Display Co.
Signs • Awnings •
(P) 240-765-1400
> Jim K.
> Fax 336.217.7983
> E-mail jimki@...
> --- In vantage@yahoogroups.com, "plamen21" <plamen21@> wrote:
> > Hello,
> > Plamen
> > Art Display Co.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of plamen21
custom BAQ
fields.
Plamen
Art Display Co.
Signs * Awnings *
(P) 240-765-1400
> Jim K.
> Fax 336.217.7983
> E-mail jimki@...
> > Hello,
> > Plamen
> > Art Display Co.
you have the SDK.
Tim Dines
801 Berryman Pike
Tipton, IN 46072
Cell: 765-437-1402
Of Manasa Reddy
a custom BAQ
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com> <mailto:
manasa@... <mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of plamen21
custom BAQ
fields.
Plamen
Art Display Co.
Signs * Awnings *
(P) 240-765-1400
> Jim K.
> Fax 336.217.7983
> E-mail jimki@...
> > Hello,
> > Plamen
> > Art Display Co.
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Dines, Tim
a custom BAQ
you have the SDK.
Tim Dines
801 Berryman Pike
Tipton, IN 46072
Cell: 765-437-1402
Behalf
Of Manasa Reddy
a custom BAQ
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of plamen21
custom BAQ
fields.
Plamen
Art Display Co.
Signs * Awnings *
(P) 240-765-1400
> Jim K.
> Fax 336.217.7983
> E-mail jimki@...
> > Hello,
> > Plamen
> > Art Display Co.
Plamen
Art display Co.
Signs • Awnings •
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> Of Dines, Tim
> a custom BAQ
> you have the SDK.
> Tim Dines
> 801 Berryman Pike
> Tipton, IN 46072
> Cell: 765-437-1402
> Behalf
> Of Manasa Reddy
> a custom BAQ
> M. Manasa Reddy
> 800.852.2325
> 630.806.2000 ofc
> 630.806.2001 fax
> www.weldcoa.com
> Behalf
> Of plamen21
> custom BAQ
> fields.
> Plamen
> Art Display Co.
> Signs * Awnings *
> (P) 240-765-1400
> > Jim K.
> > Fax 336.217.7983
> > E-mail jimki@
> > > Hello,
> > > Plamen
> > > Art Display Co.
