Hi Jeff, does the same part show up only sometimes? If one part never shows up, you might check to make sure the "generate suggestions" box is checked in the part master also. You probably already looked at this, but if it's a stocked part, and you it's in stock, or on the way, they wouldn't see a suggestion either. Depending on how the days supply, minimum buy, etc is set up they might have a suggestion to increase or expedite an existing PO.
Liz
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of maurojm
Sent: Wednesday, November 01, 2006 09:34 AM
Subject: [Vantage] Re: Purchasing question
Liz,
Thanks. That is what I thought was happening. Our engineers do
schedule the job and then purchasing runs suggestions, but SOMETIMES
a part doesnt show up to be ordered. I think that it is a user issue
and not a system issue.
Thanks again
Jeff
Liz
Liz,
Thanks again
Jeff
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Elizabeth Hahn" <ehahn@...> wrote:
> Hi Jeff,
> First off, the engineers need to make sure they schedule the job,
and then suggestions need to be re-run after that in order for the
part to show up in their suggestions to buy. It should be there
whether or not the part is marked purchase direct or not, and
whatever the leadtime is. The Lead time and Purchase direct should
be driven by the part master for that item. If you have a vendor
price break, and a vendor is marked as the default, then that lead
time has precedence over any others.
> Liz
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of maurojm
> Sent: Tuesday, October 31, 2006 11:09 AM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> Subject: [Vantage] Purchasing question
> I have a question regarding adding an assembly to a job and then
having
> it appear under purchasing suggestions. We are running 6.10.532.
> Let's say that we need Job 5 and it will contain part 1 that is in
> assembly 2. And if you look at part 1 under the part master, it is
> checked to be "Purchased Direct" and has a lead time of "999".
> When our engineers start a job they pull over assembly 2 (with part
1
> in it) thru Job Entry to Job 5. Now if you go to part 1 within Job
> Entry and look at the lead time, it is "0" and the Purchase Direct
may
> OR may not be there.
> The purchasing department says that they do not see demand if the
Lead
> Time is "0" or "Purchase Direct" isnt checked. So this is causing a
> few head aches. But it doesnt happen on all of the jobs or
assemblies.
> Long way to go but here is the question....what drives the Lead
Time
> and Purchase Direct under Job Entry? It does not appear to be
pulling
> that info form the part master. I am not sure how this functions,
but
> I am wondering if it a "User" issue vs a "System" issue
> Thank you in advance
> Jeff
