Hello,
I have done what you're trying to do where I had to modify the OrderHed.NeedByDate when creating an order from a quote using the Quote Sales Order Wizard. You will need to use the Quote.CreateOrder method to create the order. There may be some other methods you will need to use as well. Look at the Epicor.Mfg.BO.Quote.xml file in the client folder. It will give you an explanation of what each quote method does.
David Pfiester
Systems Accountant
NuStep Inc.
Phone: 734-769-3939 x150
David Pfiester
Systems Accountant
NuStep Inc.
--- In vantage@yahoogroups.com, "VantageUser13" <vantageuser13@...> wrote:
> I will need to create a BPM, in my quote when I go on Actions ==> Quote ==> Create Sales Orders. I will need to assign a Quotehed.duedate on the Orderhed.needbydate and orderhed.requestdate.
> But I don't know what Method Code to use on the BPM, and what programming code to enter ?
> If possible to create this action ?
> thanks
> Vantage 8.03.408b
