Quote Worksheet - Change Default from Markup to Profit?
Unfortunately, as far as I know, there is not a way to change the default. If you find one, please let me know. OUr work around is to setup a Quote Markup (under Quote Management\Setup) and create a markup that uses profit percentage, set the standard markup percentages, then apply this to all cusotmer records and any time you prepare a quote for that customer it will use the quote markup applied to that customer's record.
Virginia Joseph
Deep Hole Specialists
vjoseph@...
--- In vantage@yahoogroups.com, "brucewbrannan" <bruce.brannan@...> wrote:
> We're using Vantage 8.03.409C. When a quote is entered the default calculations are based upon Markup. I received a request to change the default to Profit. Is there a way to change this default? It's not in the Company Configuration settings, perhaps via customization or BPM.
> Thanks
