Not to beat this to death but in case anyone is interested.
1. It appears the ENTRY function will ignore multiple delimiters (tilde in
this case) and find each occurrence of the non-delimiter strings.
2. In a test database I created an order with five salespersons and a small
testing report I wrote correctly found all five. I also tried the
NUM-ENTRIES function on SalesRepList and it reported 5. The raw
SalesRepList string showed 24-04-38-56-67 (imagine tilde characters for the
dashes). So there was one tilde between each code.
3. I went back to the Salesperson list on the order header and set numbers 2
and 4 to be unused. In the order line commissions screen it correctly
showed only three reps and I had to adjust the split percentages there. I
re-ran the test report and the raw string showed as 24--38--67- with two
tildes between the codes and a dangling one at the end. But the NUM-ENTRIES
was now 3 and the reps and the percentages all showed correctly in the
report. If there are variable numbers of tildes on orders it might possibly
be related to the positions used by the person entering the order header.
If they are skipping around, perhaps to make it easier to read, it might
produce the multiple tildes between codes. Or it still might be a bug.
So I am pretty sure setting a report up with:
Rep1 = ENTRY(1,SalesRepList,Tilde)
Rep2 = ENTRY(2,SalesRepList,Tilde) and so forth thru 5 will get them all
and allow linking to alias SalesRep tables to get all the names.
-Todd C.
pjw@...]
Sent: Tuesday, August 21, 2001 1:01 PM
To: '
vantage@yahoogroups.com'
Subject: RE: [Vantage] Re: RB - Split Commissions & Sales Rep List
Nice work Todd,
Now that I can at least strip out the first Sales Rep, I can create a report
builder report which prints a customer Acknowledgement Form that
reacknowledges orders with a lot of releases which the crystal version
doesn't do.
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.00.317, Progress 9.1a
caugheyt@...]
Sent: Tuesday, August 21, 2001 9:40 AM
To: '
We are on version 4. So far it is working OK for up to two rep codes (the
most we split so far) of one or two digits each using the ENTRY function and
creating a constant I call Tilde with the CHR function
Tilde=CHR(126) ENTRY(1,SalesRepList,Tilde)
If I have more than two I will keep a close eye out for it in case it can't
resolve which entry number in the list. I wonder if this might be due to
the way the screen temp widgets are being put together in the string saved
as SaleRepList. The link to the SaleRep table is working well for both 1
and two digit codes so I know I am getting them OK. When specifying no
delimiter in
the ENTRY function it returned 1 digit codes as the number plus a tilde
character and this would not link.
Thanks for the heads up on the bug.
-Todd C.
ggrenier@... [mailto:
ggrenier@...]
Sent: Tuesday, August 21, 2001 9:23 AM
To:
Subject: [Vantage] Re: RB - Split Commissions & Sales Rep List
This problem with the tildes is known by Epicor. I worked with tech
support for a while on this problem. I was eventually told that it would
be "corrected in a future release". Take that as you will. Are you on
version 5? We are on 4 and I gave up trying to separate the reps in the
SalesRepList field. All of our reps have a four character code, but there
was no pattern to the tildes. The number of tildes between the two reps in
the list would vary from one to four.
Gary Grenier
IT Manager
Bell Manufacturing Co.
ggrenier@...
caugheyt@...>
Subject: RB - Split Commissions & Sales Rep List
...questions about the SalesRepList field on
the Order Header:
1. When I print it the reps are seperated by the tilde character (~). I
finally figured out how to parse out the rep codes but had to create a
string field for CHR(126) rather than use '~' in the ENTRY function. Just
curious why this character can't be used in a direct string (inside quotes
that is). Also the data dictionary says the list is seperated by commas
but
this does not seem to be the case...
-Todd Caughey
Harvey Vogel Mfg. Co.
Yahoo! Groups Sponsor
http://rd.yahoo.com/M=207641.1565480.3121573.1269402/D=egroupweb/S=17050071
83:HM/A=765263/R=0/*
http://www.verisign.com/cgi-bin/go.cgi?a=b15334027000300
http://www.verisign.com/cgi-bin/go.cgi?a=b15334027000300>
0>
http://us.adserver.yahoo.com/l?M=207641.1565480.3121573.1269402/D=egroupmai
l/S=1705007183:HM/A=765263/rand=562503292>
http://groups.yahoo.com/group/vantage/files/.>
http://groups.yahoo.com/group/vantage/files/.> >
http://groups.yahoo.com/group/vantage/messages>
http://groups.yahoo.com/group/vantage/messages> >
http://groups.yahoo.com/group/vantage/links>
http://groups.yahoo.com/group/vantage/links> >
http://docs.yahoo.com/info/terms/ <
http://docs.yahoo.com/info/terms/> > .
0>
l/S=1705007183:HM/A=765263/rand=192081763>
http://docs.yahoo.com/info/terms/> .
