**Correct Way Using the Sandbox **
To read a file in your function, instead of this:
using (StreamReader reader = new StreamReader(Path.Combine(filePath, FileName)))
var filePath = new FilePath(ServerFolder.CompanyData, "SubFolder", "FileName.txt");
using (var streamReader = this.Sandbox.IO.File.OpenText(filePath))
string line = streamReader.ReadLine();
this.output = $"First line: {line}";
Key Fixes
FilePathis used instead of raw string paths.this.Sandbox.IO.File.OpenText(filePath)is used instead ofnew StreamReader(...).
Example Folder Setup
You can only use ServerFolder.CompanyData or ServerFolder.UserData. So if your file is in \\EpicorServer\CompanyData\Folder_Name\myfile.txt, the correct path would be:
var filePath = new FilePath(ServerFolder.CompanyData, "Folder_Name", "myfile.txt");
SaaS
var folderPath = new FilePath(ServerFolder.CompanyData, "Folder_Name");
folderPath.Combine(this.FileName);
var filePath = folderPath;
I personally add sections like this to functions that use uploaded files.
// Rename the file to a unique name if it already exists
string uniqueFileName = Guid.NewGuid().ToString() + "_" + this.callContextClient.CurrentUserId + "_" + this.FileName;
var backupPath = new FilePath(ServerFolder.CompanyData, "Folder_Name");
backupPath.Combine(uniqueFileName);
if (this.Sandbox.IO.File.Exists(filePath))
this.Sandbox.IO.File.Move(filePath, backupPath, overwrite: true);
filePath = backupPath;
