I have a few Custom Sheets created that already in a customization. I now ran into an issue needing to rearrange some of them but when choosing to edit the custom sheet, the “Parent Sheet” field is grayed out.
Is it possible to change the Parent Sheet of a Custom Sheet? Or will each of these sheets need to be recreated…?
You can attempt editing surgery on the xml to change parent GUIDs and the like but other than making minor tweaks my attempts usually don’t work out so well. The cleanest way is to drop and recreate them. If you aren’t changing the parent but just want to change the order of the tabs you can do that by dragging the tab where you want it, save, exit and come back in and the tab should be where you left it.
