Report Builder Date Calc
If your fiscal periods are the same as your calander months aren't both
columns of your report such as prior fiscal period and prior month the same?
Also a thanks to Doug Williams at Epicor for the help with the formulas, if
you have been following this thread check out the CurrentMonthLastDay
calculation.
Also note these formulas attempt to figure out beginning and ending dates
with out doing long string calculations and IFF statements because when you
go this route you have to watch for year ends, leap years, etc...
Summary:
CurrentMonthFirstDay = TODAY() - DAY(TODAY()) + 1
CurrentMonthLastDay = TODAY() + (32 - DAY(TODAY())) -
DAY(TODAY() + (32 - DAY(TODAY())))
LastMonthLastDay = TODAY() - DAY(TODAY())
LastMonthFirstDay = DATE(SUBSTRING(STRING(LastMonthLastDay),1,3) +
STRING("01") + SUBSTRING(STRING(LastMonthLastDay),6,3))
NextMonthFirstDay = CurrentMonthLastDay + 1
Patrick Winter
sSc Specialty Screw Corporation
Vantage 5.10.130, Progress 9.1C
Sent: Thursday, October 02, 2003 7:35 AM
To: pjw@...
Subject: RE: [Vantage] Report Builder Date Calc
Our fiscal periods are simply 01=January, 02=February, etc.
Sent: Wednesday, October 01, 2003 3:33 PM
To: Todd Hofert
Give me a minute, I'm getting a headache.
Your going to create a calculated field to figure out the 2002 or 2003 and
insert it in your existing MTD2002 and MTD2003 calculated fields. You may
want to call your calculated fields (MTD2002) This_Year_MTD and
Last_Year_MTD since we want the dates calculated automatically.
We are also going to try to figure out the "09" fiscal period in the formula
automatically. By creating a calculated field and inserting in there also.
Calculated Field Name = Last_Year_MTD IFF(InvoiceHead.FiscalYear = Last_Year
And InvcHead.FiscalPeriod = Last_Year_Fiscal_Period ,ExtPrice,0)
That't how they get inserted now we need to figure out the formula for:
Last_Year and Last_Year_Fiscal_Period.
Last_Year will be something like:
YEAR(TODDAY() - 365)
Fiscal Period I'm not sure how you are setup?
Patrick Winter
Sent: Wednesday, October 01, 2003 1:23 PM
To: pjw@...
Patrick,
My current criteria are as follows:
Calculated Field Name = MTD2002
IFF(InvoiceHead.FiscalYear=2002 And InvcHead.FiscalPeriod=09,ExtPrice,0)
Calculated Field Name = MTD2003
IFF(InvoiceHead.FiscalYear=2003 And InvcHead.FiscalPeriod=09,ExtPrice,0)
Calculated Field Name = YTD2002
IFF(InvoiceHead.FiscalYear=2002 And InvcHead.FiscalPeriod<=09,ExtPrice,0)
Calculated Field Name = YTD2003
IFF(InvoiceHead.FiscalYear=2003 And InvcHead.FiscalPeriod<=09,ExtPrice,0)
This sticks the invoices into the appropriate "bucket". I then aggregate
each "Bucket" and print it on the report. How then do I implement your code
listed below (calendar fiscal year) to make these "buckets" to total on?
Todd
Sent: Wednesday, October 01, 2003 2:14 PM
Last Day of Last Month is = LDLM = TODAY() - DAY(TODAY)
First Day of Last Month is = FDLM = DATE(SUBSTRING(STRING(LDLM),1,3) +
STRING("01") + SUBSTRING(STRING(LDLM),6,3))
My fiscal year starts July 1st, This is for Fiscal Year Start Date:
IIF(MONTH(TODAY()) > 6, DATE("07/01/" +
SUBSTRING(STRING(TODAY()),7,2)),DATE("07/01/" +
SUBSTRING(STRING(TODAY()),7,2)) - 365)
Patrick Winter
Sent: Wednesday, October 01, 2003 1:09 PM
OK then, while we are on the subject. I have a dozen sales reports that I
run at the beginning of each month for the previous month. These reports
have calculations using InvoiceHead.Fiscal Year and Fiscal Period to total
sales dollars by Last Month Month to Date, Last Year Last Month Month to
Date, Year to Date through Last Month and Last Year Year to Date through
Last Month. Problem is I have to manually edit each of these dozen or so
reports each month to plug in the appropriate fiscal period. It is a hassle.
Anyone know how I can create calculations a filters that will do this
without my intervention?
Todd Hofert
IT Director
Spartan Graphics, Inc.
Sent: Wednesday, October 01, 2003 1:52 PM
To: 'vantage@yahoogroups.com'
Create two calculated fields MonthStart and MonthEnd
MonthStart:
Date_rb + 1
MonthEnd:
IIF(MONTH((Date_rb + 1)) = 12, DATE("01/01/" + STRING(YEAR(Date_rb) + 1,
"9999")), DATE(STRING(MONTH((Date_rb + 1)) + 1, ">9") + "/01/" +
STRING(YEAR(Date_rb), "9999")))
Then set your filter to quotes >= MonthStart and quotes < MonthEnd
This should work as long as it is run on the last day of the month,
otherwise you can create a long MonthStart which works off the current day
and moves it to the next month.
Sent: Wednesday, October 01, 2003 12:40 PM
Subject: [Vantage] Report Builder Date Calc
I'm have a report that will run using the AutoRpt Utility and will pull all
quotes set to expire next month. For instance, the report will be run on
September 30, 2003 and should pull only those quotes that are set to expire
from October 1, 2003 to October 31, 2003.
Can anyone help me with the filter/calculation fields to do this? I can't
seem to get it to work properly.
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Des Plaines, IL 60018
Fax: 847-827-6733
PH: 847-827-6680 x223
www.plitek.com
all quotes set to expire next month. For instance, the report will be
run on September 30, 2003 and should pull only those quotes that are set
to expire from October 1, 2003 to October 31, 2003.
can't seem to get it to work properly.
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
Patrick Winter
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
MonthStart:
Date_rb + 1
MonthEnd:
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
Thanks Mike and Patrick....I'm printing these and keeping them for
future reference. This date filtering thing comes up every once in a
while...usually I can solve it, but this time I was stumped.
I was finally able to put one together by adding the Calculation
field...
NextMonthExpire = IIF(Year(ExpirationDate) = Year(Today()) and
Month(ExpirationDate) = Month(Today()) + 1, True, False)
Then, I added a filter to see if NextMonthExpire = True
It seems to work!!
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
Sent: Wednesday, October 01, 2003 12:52 PM
MonthStart:
Date_rb + 1
MonthEnd:
day
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
have
and
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=256694.4002236.5216697.1261774/D=egroupweb/S=1705
007183:HM/A=1784493/R=0/id=noscript/SIG=11q7p9e7k/*http://webevents.yaho
o.com/universal/intolerablecruelty/>
<http://us.adserver.yahoo.com/l?M=256694.4002236.5216697.1261774/D=egrou
pmail/S=:HM/A=1784493/rand=259686600>
You may have trouble with your formula in when running the report in
December.
Patrick Winter
Sent: Wednesday, October 01, 2003 1:05 PM
Thanks Mike and Patrick....I'm printing these and keeping them for future
I was finally able to put one together by adding the Calculation field...
It seems to work!!
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
MonthStart:
Date_rb + 1
MonthEnd:
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
ADVERTISEMENT
OK then, while we are on the subject. I have a dozen sales reports that I run at the beginning of each month for the previous month. These reports have calculations using InvoiceHead.Fiscal Year and Fiscal Period to total sales dollars by Last Month Month to Date, Last Year Last Month Month to Date, Year to Date through Last Month and Last Year Year to Date through Last Month. Problem is I have to manually edit each of these dozen or so reports each month to plug in the appropriate fiscal period. It is a hassle. Anyone know how I can create calculations a filters that will do this without my intervention?
Todd Hofert
IT Director
MonthStart:
Date_rb + 1
MonthEnd:
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
Good catch...here I thought I was sooo smart!
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
Sent: Wednesday, October 01, 2003 1:06 PM
December.
Patrick Winter
future
field...
It seems to work!!
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
MonthStart:
Date_rb + 1
MonthEnd:
day
all
on
expire
can't
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
have
and
ADVERTISEMENT
have
and
have
and
ADVERTISEMENT
pmail/S=:HM/A=1784493/rand=826428967>
Patrick Winter
Todd Hofert
IT Director
MonthStart:
Date_rb + 1
MonthEnd:
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
This could be very complex depending how your fiscal periods are defined in
Vantage. The best solution I would have for this is to create a progress
routine that reads the Vantage database for the last closed fiscal period.
Then use that data to pass along to the reports. I know exactly how much a
pain this is, come the first of the year we are changing from our calendar
month fiscal periods to a 4-4-5 week setup so that each fiscal period will
end at the end of the week. I have approx 20 automated reports I need to
adjust to use this calculation by year end. I've already found a way to run
AutoRpts using the dates from the Vantage Fiscal Period table (FiscalEnd and
FiscalStart), now just to figure out how to and get the calculations working
in the reports themselves.
Todd Hofert
IT Director
MonthStart:
Date_rb + 1
MonthEnd:
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
Michael & Todd -
Suggestion: use a field on the Company table that could hold your
fiscal period for reporting? If you're not using EDI - enter
the current fiscal period for reporting into the EDI field.
Then point the dozen or so reports to feed off of that field.
Would require updating once per change instead of more than
a dozen times.
Moreover, link the fiscal period table and query the rbdate
between the start and end dates to obtain the period program-
matically. You could program in a buffer for month starts
to review the previous period.
HTH,
Misha 1, Ltd.
Calvin Dekker
Sent: Wednesday, October 01, 2003 1:40 PM
Todd Hofert
IT Director
MonthStart:
Date_rb + 1
MonthEnd:
Sincerely,
Judy Havlik
Plitek, L.L.C.
69 Rawls Road
Fax: 847-827-6733
www.plitek.com
