Report Builder Help
I am creating a report that would list all our shop floor employees (Table:
Empbasic). I want the employee ID, the employee name and supervisors name.
The problem is that the supervisor is specified by their employeeID not
their name. Is there a function I can use to look-up the name of the
supervisor and print it on my reports?
Martin Nijdam (Jr. Ing.)
Suss Woodcraft Int'l
(514) 363-3565
Martin,
Join the EmpBasic table to itself - you will need to create an
alias for the second instance of the table (EmpBasic2). Join on
EmpBasic.Company - EmpBasic2.Company; EmpBasic.SupervisorID -
EmpBasic2.EmpID. The join will be left outer.
have fun,
John
> -----Original Message-----
> From: Martin Nijdam [mailto:martinn@...]
> Sent: Monday, July 31, 2000 10:06 AM
> To: 'vantage@egroups.com'
> Subject: [Vantage] Report Builder Help
I've got a bit of a pickle you could help me with. I'm fine tuning my labor
exception report.
My evening shift ends at midnight (00:00). I want to print a message "out
late" if they the personnel punch after midnight (ex: 00:15). I want to
print "out early" if the personnel punch before midnight (ex: 23:34).
Any idea how I could write the report builder calculated field?
(514) 363-3565
Hi Martin,
Give this a try...Use the IIF statement with your function. It should
go something like this.
IIF(ClockOutTime > 0000, "Out Late", IIF(ClockOutTime < 0000, "Out
Early", "Out At Midnight"))
The statement says If ClockOutTime is past 00:00, "Out Late" will
print. If the first part is false, the statement tests to see if
ClockOutTime is < 00:00. If that is true, "Out Early" will print. If
both tests of the ClockOutTime are false, it must be 00:00, and "Out
At Midnight" will print.
Erik Smalley
IT Manager
Milford Enterprises Inc.
Unfortunatly your statement does not work as both 00.50 (half past midnight)
and 23.50 ( 11:30 PM) are bigger then 0000. Your statement will always print
"Out Late" (unless they punched out exactly at midnight).
The problem in my opinion is that vantage does not have a ClockOutDate field
in the LaborHed table. I really think there is no solution to my problem
unless someone can prove me wrong!!!
(514) 363-3565
> From: E. Smalley [SMTP:esmalley@...]
> Sent: Tuesday, November 14, 2000 5:06 PM
> To: vantage@egroups.com
> Subject: [Vantage] Re: Report Builder Help
> Hi Martin,
> Erik Smalley
> IT Manager
Martin Try playing around with this statement if the clock out time is less
than the clock in time I added a day to the date..Hope it helps....I use
reportbuilder to export all time and date for employee to import into my
payroll program. I had the same problem with night shift.
If this string is not enough I could send you the whole report file,
iif (ClockOutTime<ClockInTime,string(day(ClockInDate) + 1,"99")
,string(day(ClockInDate),"99"))
> From: Martin Nijdam [SMTP:martinn@...]
> Sent: Wednesday, November 15, 2000 8:26 AM
> Subject: RE: [Vantage] Re: Report Builder Help
> midnight)
> print
> field
> (514) 363-3565
> > Hi Martin,
> > Erik Smalley
> > IT Manager
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
What about changing the equation to where if the "out early" is a range of
beginning for the shift to the minute before the end of shift and doing the
same for "out late" like below.
IIF(ClockOutTime > 00:01 < 16:00, "Out Late", IIF(ClockOutTime < 23:59 <
16:00, "Out
Just a thought.
Jim Frice
> Sent: Tuesday, November 14, 2000 4:26 PM
> past midnight)
> always print
> ClockOutDate field
> (514) 363-3565
> > Hi Martin,
> > Erik Smalley
> > IT Manager
> Files, please go to the following link:
I would like to extract the Customer Name out of the description field in
the gljrndtl table. The description for every invoice that hits the sales
account starts with the invoice number then a space and then the Customer
Name. (ie.."IV:00634 THE MILWAUKEE BUCKS). I do this with a replace
function in Lotus but I'm not sure how to do it in RB.
substring(Description,9,10)
9 tells it which character to begin with and 10 says how many characters you
want of it.
You would get The Milwau
Adapt the 10 to how many you need in order to tell one Customer from
another. Only problem is if you deal with a customer and they have multiple
Sold To's and you also need to know the difference.
Sent: Tuesday, May 22, 2001 4:34 PM
To: 'vantage@yahoogroups.com'
field in
sales
Customer
replace
To access the Files Section of our Yahoo!Group for Report Builder
and Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have already
linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Hi,
I know how to get the report Filter into the Title of a report. How do I
get just a part of that expression.
If you create a variable "ReportFilter" using the function "REPORT-FILTER()"
it returns:
"Include all records where JobNum is equal to 007661-5-1" I want to put
just the 007661-5-1 or whatever it happens to be on the report.
If I put "SUBSTRING(REPORT-FILTER(),45,10)" I get a Syntax Error
If I define "rptFilter" to be "REPORT-FILTER()" and put
"SUBSTRING(rptFilter,45,10)" I get the error "REPORT-FILTER() used
indirectly"
Dave Cole
Reeder & Kline
Run the report filter thru an aggregate funciton (such as minimum) and use
the result in the substring.
-Todd C.
Sent: Monday, September 23, 2002 11:07 AM
To: eManfacturing Yahoo Groups (Vantage@...)
Hi,
it returns:
indirectly"
Dave Cole
Reeder & Kline
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=229441.2397090.3822005.1261774/D=egroupweb/S=17050071
83:HM/A=1189558/R=0/*http://www.bmgmusic.com/acq/ee/q6/enroll/mhn/9/>
<http://us.adserver.yahoo.com/l?M=229441.2397090.3822005.1261774/D=egroupmai
l/S=:HM/A=1189558/rand=199555454>
Todd,
Thanks a lot!! Passing it through an aggregate function fixed the problem.
Dave Cole
Reeder & Kline
Sent: Monday, September 23, 2002 11:09 AM
Subject: RE: [Vantage] Report Builder Help
-Todd C.
Hi,
it returns:
indirectly"
Dave Cole
Reeder & Kline
ADVERTISEMENT
<http://www.bmgmusic.com/acq/ee/q6/enroll/mhn/9/> >
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
83:HM/A=1189560/R=0/*http://www.bmgmusic.com/acq/ee/q6/enroll/mhn/10/>
l/S=:HM/A=1189560/rand=496140607>
I need to create a job report that will sort by the people, or the
person list in the job header. The job needs to show under each
person. So some jobs will be listed under one person and then again
under another person. I did a calculation to look for matches on the
personlist field, but once it finds the first match in the
calculation it doesn't look any more. I'm using the personlist in the
job header, should I use something else or should I do a different
calculation.
Any help would be greatly appreciated.
Helen
Niven Marketing
Start with the Person table as the master then left outter to jobs check
with an 'IF Statement' to see if the person is in the jobhead.person
delimited list. Works like sales rep report provided on the epicor site.
Will be slow to run but should work.
Patrick Winter
Sent: Wednesday, July 30, 2003 10:22 AM
calculation.
Helen
Niven Marketing
Patrick,
Thanks for your input, I set the report up that way but the job only
appears once under one person. It does not appear under all the
people in the person list.
Any ideas?
Helen
check
site.
> Patrick Winter
> From: hebarna [mailto:hbarna@p...]
the
the
> calculation.
> Thanks,
> Helen
> Niven Marketing
must have
Builder and
Helen
My mistake, the IF statement is probably just getting you the first entry in
the string, which gives you just one listing of a job.
Try designing it like the sales rep report on epicors web site. Epicor used
the LOOKUP command so yours would look something like:
LOOKUP(Person.PersonID,JobHead.PersonList,"~~")
The you can conditionally print the line only when there is data.
Patrick Winter
Sent: Thursday, July 31, 2003 8:56 AM
Patrick,
Any ideas?
Helen
check
site.
> Patrick Winter
the
the
> calculation.
> Thanks,
> Helen
> Niven Marketing
must have
Builder and
Patrick,
I did just that, I've been using Epicor's report. I created that
exact lookup statement, then creatd an if statement that says if the
lookup statement = 1 (meaning it found a match) then print the Person
ID. So I'm grouping on that second calculation, with the record being
the job #'s. But, for example, if I have Jon and Ray in the person
list on the job, it only shows the job# under Jon, and not Ray. I
need the job number to show under every person in the list. I'm still
playing around with it, but any suggestions would be helpful.
Helen
> Helen
entry in
Epicor used
> Patrick Winter
> Patrick,
only
> Any ideas?
> Thanks,
> Helen
> check
jobhead.person
> site.
> > Patrick Winter
again
> the
> the
> > calculation.
> > Thanks,
> > Helen
> > Niven Marketing
> must have
access. )
> Builder and
must have
Builder and
Patrick,
I wasn't paying attention, I thought that that the result of the
lookup function (1) meant true, but it is returning the position of
what you are looking for. So I changed the if statement to say if it
dosen't equal zero to use the person id, (which it how the Epicor
report works). Now it shows the jobs under each person.
Thanks for your help.
Helen
--- In vantage@yahoogroups.com, "hebarna" <hbarna@p...> wrote:
> Patrick,
the
Person
being
still
> Thanks,
> Helen
> > Helen
first
> entry in
> Epicor used
> > Patrick Winter
> > Patrick,
> only
> > Any ideas?
> > Thanks,
> > Helen
jobs
> > check
> jobhead.person
epicor
> > site.
> > > Patrick Winter
the
> again
on
> > the
in
> > the
different
> > > calculation.
> > > Thanks,
> > > Helen
> > > Niven Marketing
You
> > must have
> access. )
> > Builder and
> must have
access. )
> Builder and
I knew you were close to getting it running.
Patrick
Sent: Thursday, July 31, 2003 11:05 AM
Patrick,
Helen
> Patrick,
the
Person
being
still
> Thanks,
> Helen
> > Helen
first
> entry in
> Epicor used
> > Patrick Winter
> > Patrick,
> only
> > Any ideas?
> > Thanks,
> > Helen
jobs
> > check
> jobhead.person
epicor
> > site.
> > > Patrick Winter
the
> again
on
> > the
in
> > the
different
> > > calculation.
> > > Thanks,
> > > Helen
> > > Niven Marketing
You
> > must have
> access. )
> > Builder and
> must have
access. )
> Builder and
LeavesHello,
I am writing a report that shows quoted jobs in a particular time period,
whether the quote was ordered, the order quantity, and unit price. My
problem is the lines are duplicating. If there are two lines in the quote,
each line appears 2 times, if there are 3 lines, each line appears 3 times
and so on. I have tried every approach that I know to get this to stop with
no luck. Any help is appreciated. Also, if any of you have an RB or Crystal
report similar to this, can I please get a copy?
Also, does anyone have a report that shows the quoted set-up and production
hours vs.. actual set-up and production hours?
Karen Brodniak
Accounting Manager
425-742-7011 X44
Fax 425-353-8945
karen.brodniak@...
