Shirley -
Another option would be to run the report repeatedly (once for each column)
with an algebraic stepping through the data to match the number of rows per
page adjusted for the number of columns.
The same report could be copied and the stepping equation modified and the
column location 'slid' over.
Just an idea,
Calvin
ps: Don't jumble the order of the print outs between iterations!
Just an idea,
Calvin
----- Original Message -----
To: <vantage@egroups.com>
Sent: Friday, September 01, 2000 9:08 AM
Subject: Re: [Vantage] Re: Report builder Question?
> Thanks guess thats my only option.
> Shirley Graver
> Sys Admin
> Rubber Associates
> Cleveland/Akron
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
