Just noticed this, so apologies for delay in response.
I suspect that you are finding a memo where the memouserid is some value other than the specified, and you in effect printing a blank line. To test this try changing the false entry to print something. e.g.
IIF(MemoUserID="chuckm",MemoText,"Not Mine")
and run your report. if the result looks like this:
WCCode Description PartNum JobNum StartDate Memo
12345 Fadal 30" 567834 234 12/04/2000 Not Mine
Ready to Machine
then you are selecting an other memo record. Review the way you select the memos that you want to print.
HTH.
Charles Metcalf wrote:
William E. Colls Tel 613 591 0079
PROComputer Systems Fax 613 591 3924
67 Willow Glen Dr www.procomsys.com
Kanata Ontario Canada PEG Member 1998051404
Specialists in Progress Software development since 1985
Ready to Machine
HTH.
> The formula I use is:--
> IIF(MemoUserID="chuckm",MemoText,"")
> The problem I am having is my report looks like this:
> Ready to Machine
> My memos are offset from the line they should be on. I have tried everything
> but the right thing.
> Thanks
> Chuck
> -----Original Message-----
> From: Jim Frice [mailto:Jim.Frice@...]
> Sent: Monday, December 04, 2000 12:38 PM
> To: vantage@egroups.com
> Subject: RE: [Vantage] Repost
> Chuck are you using the memodesc or do you have categoryID's set up? It
> would probably be easier if you have categoryID's. But you can use formula
> to print only the ones that = the categoryID's you desire. Descriptions
> would have to be exact which can be a problem sometimes.
> > From: Charles Metcalf [mailto:chuck_metcalf@...]
> > Sent: Monday, December 04, 2000 9:28 AM
> > Subject: [Vantage] Repost
> > I did not receive any responses to this question.
> > I have written a scheduling report using Report Builder. I am using
> > jobhead, joboper, wrkcenter, and memos. My problem is, if there is
> > more than one memo description it brings the memo from each memo
> > description. I want to specify which memo description to use, ie. if
> > the memo descriptions are "Purchasing", and "Scheduling", and I want
> > to use the memotext only from "Scheduling", how can I do this.
> > I am stumped, can anyone help??
> > Thanks
> > Chuck
> > We no longer allow attachments to files. To access/share Report
> > Files, please go to the following link:
> > http://www.egroups.com/files/vantage/
> > (Note: If this link does
> > not work for you the first time you try it, go to
> > www.egroups.com, login and be sure to save your password, choose
> > My Groups, choose Vantage, then choose Files. If you save the
> > password, the link above will work the next time you try it.)
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to
> www.egroups.com, login and be sure to save your password, choose My Groups,
> choose Vantage, then choose Files. If you save the password, the link above
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
