Version 803.305L
Don,
Sorry, no answers for you we have the same concern. Misery loves company.
Maybe a newer version of vantage behaves differently. What version are you on?
Sometimes we want to combine multiple requisitions/purchase suggestions for the same part into one PO line with multiple releases. But in the "real" world there are times when we do not want to do this. Example would be a.) if the price is going to change from one release date to another or b.) if we would like to have specific instructions for that particular release, such as "supplier Lot codes" for each shipment .....because vantage does not have release level pricing or release level comments we have these issues. It happens much more frequently than most would think.
Another issue is that vantage does not force a new line on a po for a requisition/purchase suggestion.
ONLY if that part # already exists on the po will it add a release to the line if you enter the po & line to the po suggestion before the "generate po" command is chosen. AND the PO must be unapproved.
We would support any enhancement activities in this matter.
Matt Sweny
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Don Kollmann
Sent: Wednesday, October 06, 2010 11:33 AM
Subject: [Vantage] Requisition to Order 8.03409A
Hi Group,
When creating a purchase order from a Requisition is it possible to default the the system to create separate lines instead of releases
if the parts are the same but different dates?
Thank You
Don
Disclaimer:
This email transmission and any attachments to it are intended solely for the use of the individual or entity to whom it is addressed and may contain confidential and privileged information. If you are not the intended recipient, your use, forwarding, printing, storing, disseminating, distribution, or copying of this communication is prohibited. If you received this communication in error, please notify the sender immediately by replying to this message and delete it from your computer.
Don,
Matt Sweny
Hi Group,
Thank You
Don
Disclaimer:
