And just so you all know up through version 10 the system does not inventory by revision. Julie’s method has been the only easy way some of us have seen around this issue.
Manasa
Sent: Wednesday, November 18, 2015 12:09 PM
Subject: RE: [Vantage] Revision level not available one parts go into stock - Vantage 8.03
Mike,
We switched to a system using the rev number as part of the part number, and every time the revision changes it becomes a new P/N in the system.
We also use the Vendor/Customer P/N fields to show the P/N without the “–REV-x” where necessary to keep things clear and match their PO/CO.
We went around and around about implementing this change, but after using the system that way for a couple of years, we see the benefits on a day-to-day basis. We no longer find ourselves using
a part down level without making the conscious decision to do so. We can have inventory and use multiple rev levels of parts and since they are identified differently, we know how much of each is in stock.
We don’t have the issues like we used to of using the wrong rev level or not being able to track when the change was implemented. I’m sure there are other ways to accomplish this, but that is how we successfully
solved the problem here.
Good luck!
Julie Lehmann
Mercury Minnesota Inc.
Sent: Wednesday, November 18, 2015 9:33 AM
Subject: [Vantage] Revision level not available one parts go into stock - Vantage 8.03
Was wondering what some of you do to handle different revisions of a part number that may be in stock? Looking in the partbin table, Vantage doesn’t keep track of what revision of the part is in the bin location. It does keep the Lot Number (which we use) but what is the best practice for handling other parts that may be revision controlled but not have lot numbers? How do you keep track as to what is in inventory. Is this also how it works in Epicor 9?
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone: +1 931 432 8408
Fax: +1 931 432 1889
Mail:
mabell@...
Website: http://www.flexial.com
http://www.boagroup.com
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2016.0.7227 / Virus Database: 4457/11019 - Release Date: 11/17/15
Version: 2016.0.7227 / Virus Database: 4457/11022 - Release Date: 11/18/15
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
