I do not know whether to with you or with you. I think I am doing both. There needs to be something we can do here, even if there is a known solution and a bad Configuration. I have to say seeing that message from you this morning I feel much better that you have already resolved it. Iām going to check around internally for options and get back to you.
Yeah in the very least it shouldnāt allow me to have a URL in that Sys Agent screen that sināt pointing to the ācurrentā Db.
In your case it would need to be checked on every subtask creation.
@josecgomez so after the first 5 minutes we are struggling. Just so you know exposing DB connection info of any sort will get us shot and deservedly soā¦ So we have been discussing hashingā¦ do we need that column anymore? Validation time checking vs runtime checking and impact on performance. We did not talk long because my Task Agent expert is on PTO today but it isnāt going to get solved in a 5 minute chat, it might over a beer though. Iām adding it to by todo list for next week.
Something as simple as having a response back 404 task not found when a task is sent to the sys agent, should be a very quick 1=1 lookup so that at least the App Server / Agent can respond back and let it know the task that was sent for work doesnāt exist.
That could / should then raise alarms and mark the tasks as āerrorā
It already sends a TaskID to process (is how I found the issue because the TaskIDās being sent to SQL were not in the Db) so if that initial call did a very quick primary key indexed lookup to verify that the Task (at least exists) it may go a long way.
But yeah I can see the complexity.
Thanks for looking at it so quickly.
Also consider not flooding our Event Log whenever MC, MRP or Scheduling is runningā¦ which all take 3+min especially Continuous MC or MRP may take up to 3-8hrs.
You can edit your config via notepad but consider making the default like 6-8hrs instead of 3 minutes.
I literally have 100K warnings.
@josecgomez Sorry for you misery, but also thanks. I added this to my restore script as something to clear.
Greg
As will I, hoping to go live with and automatically refreshed dev this week.
Thanks for publishing @josecgomez
Yeah it was a brand new field for us and we didnāt have it on the script.
You bet it is now !!! lol
Why is my foot hurting !??!?!
ā¦oh crap I shot myself in the foot again! At least I recognised the symptoms and could fix itā¦
Add it to your restore script (itās what we did)
