Running progress .r code from a client
This is great topic IMHO.
I added the button to Vantage (customisation) and I am able now to
launch 4GL procedure from Vantage. The question is... how can I aquire
the results from 4GL procedure into tt table in Vantage?.
I am running the procedure form UD form.
Grzegorz Szczepañski
--- In vantage@yahoogroups.com, "Podlin, Michael" <michael.podlin@...>
wrote:
> You'll have to launch the progress program from a command line with
the -param "parameters" command.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf Of mjhoney71
> Sent: Wednesday, January 21, 2009 7:14 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Running progress .r code from a client
> Vantage 8.03.407
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
"Podlin, Michael"
> <michael.podlin@> wrote:
> > Vantage 6.x and below or Vantage 8.x and above?
> > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
> Behalf Of mjhoney71
> > Sent: Tuesday, January 20, 2009 3:47 PM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > Is there a way to pass parameters to a progress program from inside
> > Vantage? Any good examples or even general references would be
> greatly
> > appreciated.
> > Marc
I'm not exactly sure what to ask but basically what I want is to be
able to run a progress .r program supplied to me from a workstation
that does'nt have a full version of progress installed, only the
network version. From what I understand, the .r file is a compiled
Progress program that "should" run from a client. In fact, if I simply
double click the file from Windows Explorer is launches some type of
progress interpreter but gives me a 1006 error basically stating it's
not connected to a database. This gives me the impression that if I
created a shortcut to the .r file and supplied the correct command line
parameters I might be in luck. Ideally I would like to connect to the
Progress database on our server through the ODBC connector on the
workstation.
Any pointers or clues are greatly appreciated.
Marc
Marc,
You are correct in assuming that you can do this by creating a
shortcut and placing the correct parameters in it. When you create
the shortcut you will want to use:
TARGET:
\\DBservername\epicor\oe101b\bin\prowin32.exe -db
\\DBservername\epicor\mfgsys803\db\mfgsys.db -S 8300 -H DBServername
-N TCP -p "location and name of .r file" -s 200 -B 2000 -U sysprogress
-P sysprogress
This will all be in one long line. This will connect you to your LIVE
progress database running OpenEdge 10.1B. If the location/name of the
.r program you are trying to run contains spaces make sure you keep
the quotes around it.
This also assumes you chose the default folder locations when
installing Vantage and Progress. If you need any further help with
this let me know. I have different Progress reports that I have setup
using windows scheduler to run using this and it works great.
Robert Nupp
Laclede Chain Mfg.
> workstation.
> Marc
You can create an icon on the client desktop and then use full paths to
Progress, db, and program. This example is for Vantage 8.3 and Progress
10.1b.
Here is an example:
\\servername\epicor\oe101b\bin\prowin32.exe
<file:///\\servername\epicor\oe101b\bin\prowin32.exe> -db
\\servername\epicor\mfgsys803\db\mfgsys
<file:///\\servername\epicor\mfgsys803\db\mfgsys> -S 8300 (port of db) -H
server name -N TCP -p \\path <file:///\\path> of progress .r program
\programname.r -U sysprogress -P sysprogress (user and password default)
The .r will need to have been compiled under the same version that you
running with Vantage
This should work if you use the proper paths, servername, and port number.
Good luck,
mjhoney71
Sent: Tuesday, January 13, 2009 4:11 PM
Subject: [Vantage] Running progress .r code from a client
workstation.
Marc
Thank you very much, that is exactly what I was looking for, it
worked like a charm!
Marc
--- In vantage@yahoogroups.com, "robert.nupp" <robert.nupp@...> wrote:
> Marc,
> TARGET:
sysprogress
> -P sysprogress
LIVE
the
setup
> Robert Nupp
> Laclede Chain Mfg.
be
workstation
compiled
simply
of
it's
if I
command line
to the
> > workstation.
> > Marc
The shortcut is working good, but after the .r finish its execution it
lanuches an empty Procedure Editor. What could be a reason for that?
> 10.1b.
> Here is an example:
db) -H
number.
> Good luck,
Behalf Of
> mjhoney71
> workstation.
> Marc
Can be tricky.
Add the following to end of your code.
APPLY "CLOSE" to this-procedure.
quit.
return no-apply.
tomojmail
Sent: Tuesday, January 20, 2009 6:36 AM
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Carl
> 10.1b.
> Here is an example:
> <file:/// <file:///\\> \\servername\epicor\oe101b\bin\prowin32.exe> -db
> <file:/// <file:///\\> \\servername\epicor\mfgsys803\db\mfgsys> -S 8300
(port of
db) -H
> server name -N TCP -p \\path <file:/// <file:///\\> \\path> of progress .r
program
number.
> Good luck,
Behalf Of
> mjhoney71
> workstation.
> Marc
Vantage? Any good examples or even general references would be greatly
appreciated.
Marc
Well, you might be able to pass an argument to the Progress file with a
BAM. The below code is using a 4GL solution in Progress to export
parameters to an external .EXE program I wrote a long while back:
You should be able to do something similar so I would recommend looking
up Accepting Arguments in 4GL or having Declarations accept arguments.
I know how to do it in VB.NET but I doubt that helps.
/*Passes Jobnum when Labordtl.Complete is touched */
{V:\mfgsys\ud\GlbAlert.i &TableName = "LaborDtl"}
/*Plug in appropriate Operation number (integer), and WCCode (Textx5)*/
IF (LaborDtl.LaborQty >= 1) AND
(LaborDtl.WCCode = "0261") AND
(LaborDtl.COMPLETE = YES) THEN
DO:
/*Find Joboper.QtyCompleted*/
DEF VAR nQtyCompleted AS DECIMAL NO-UNDO.
FIND JobOper WHERE
JobOper.company = LaborDtl.Company AND
JobOper.Jobnum = LaborDtl.Jobnum AND
JobOper.AssemblySeq = LaborDtl.AssemblySeq AND
JobOper.OprSeq = LaborDtl.OprSeq
NO-LOCK NO-ERROR.
IF AVAILABLE JobOper THEN
nQtyCompleted = JobOper.QtyCompleted.
MESSAGE LaborDtl.WCCode VIEW-AS ALERT-BOX.
DOS VALUE("c:\BoxShopConsole.exe "
+ STRING(nQtyCompleted) + " "
+ LaborDtl.Jobnum + " "
+ string(LaborDtl.LaborQty) + " "
+ LaborDtl.Employeenum + " "
+ string(LaborDtl.LaborDtlSeq) + " "
+ string(LaborDtl.AssemblySeq) + " "
+ string(LaborDtl.WCCode))
END.
Christopher Ryhal
Senior Microsoft Consultant
Perpetual Technologies, Inc
chris.ryhal@... <mailto:chris.ryhal@...>
http://www.perptech.com
Office: (317) 824-0393
Mobile: (317) 364-2134
Of mjhoney71
Sent: Tuesday, January 20, 2009 4:47 PM
appreciated.
Marc
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of mjhoney71
appreciated.
Marc
Vantage 8.03.407
Behalf Of mjhoney71
greatly
> appreciated.
> Marc
You'll have to launch the progress program from a command line with the -param "parameters" command.
Vantage 8.03.407
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Podlin, Michael"
> From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of mjhoney71
greatly
> appreciated.
> Marc
Thank you. :).
> Can be tricky.
> quit.
> return no-apply.
Behalf Of
> tomojmail
"Carl
paths to
Progress
> > 10.1b.
> > Here is an example:
8300
> (port of
> db) -H
progress .r
> program
default)
> number.
> > Good luck,
> Behalf Of
> > mjhoney71
simply
line
> > workstation.
> > Marc
