make a copy of your Vantage.VTG file. Edit that copy so that the mainmenu.w
is your procedure.p. Then just create a shortcut to your new VTG file.
That should work.
jleonard@...]
Sent: Wednesday, November 20, 2002 7:05 AM
To: '
vantage@yahoogroups.com'
Subject: RE: [Vantage] Running a Progress Procedure
Do you have Provsion? If so, you can create your connection there and run
your procedure.
Jeremy Leonard
IT Manager
K-T Corporation
rreilly@...]
Sent: Tuesday, November 19, 2002 5:13 PM
To:
Subject: [Vantage] Running a Progress Procedure
Is it possible to set up an icon to run a procedure without having to
be in Vantage. For example I have a procedure that exports the
PREmpMas table to a csv file. I have this set up as a menu item in
vantage but I would like to run it without having to be in Vantage at
all or the procedure editor. I realize that you need to be connected
to the database in some way and I was hoping that someone had a
solution on how to do this.
Rhonda
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
