There may be a setting?
So if I understand correctly, it should gracefully fall back. If one still has trouble with code validation, then it doesn’t hurt to install .NET 6.
Correct, there is no harm in installing .NET 6 on the client. If it helps with some scenario then go for it. For the most part, you should be fine without it.
Yes, it appears the auto-update bricked the install. Got it working now
For PO suggestions - it is very common to pull in alot of data into the “workbench” to select to promote to a purchase order.
The idea is not to export the data, but use the standard process in Kinetic to manage all of the suggestions.
Right now, will be required to used the classic process to work with the suggestions.
Bruce,
I am curious how the classic process actually works. Are they:
Pulling in all suggestions across all suppliers? A group of suppliers? One supplier? (I’m assuming by Buyer)
How many suggestions are converted to orders per day? Or per Run Purchase Suggestions?
Do they review the entire list or just Select All and convert to orders?
It is my understanding Epicor will allow a 5K row limit, isn’t 5K enough? I guess batching it in 5K groups.
@LarsonSolutions Can you elaborate on this? Perhaps in a different post as I guess it’s off topic. I searched the forum but don’t see it mentioned. I mean, I know what the periodic posting is, but what do you mean by eliminating it?
Santiago I did notice issues with having .NET Core Runtime on my PC. Even Epicor aside, for example I use LINQPad and suddenly I got
The type initializer for 'Epicor.Data.EpiDataContext' threw an exception. because Serilog could not be found in Epicor.Hosting.dll (Inner Stack).
I removed .NET 6 Runtime from my PC and long and behold, all is back to normal.
I think .NET 6 should supplement .NET 4.7 but what happens it actually breaks stuff when compiling code on the PC arghhhhh! Its not an Epicor issue, just a .NET Backwards compatibility issue.
Even tho I had NuGet specific packages for EntityFramework, somehow .NET 6 Runtime messed it up.
Now I can explain this too ![]()
Basically - Remove .NET 6 Runtime from your Client PC and all your BPMs and issues will be resolved and you wont have to include some special assembly in your BPMs.
SHEESH!
“this is a complete sentence.”
Doing some testing this morning on 2022.2
Job Tracker
Doing a quick spot check - the speed is good on both single level assemblies with 300+ materials and jobs with four subassemblies with 100+ materials each.
Very pleased with the results.
PO Suggestions
I was able to return 1,000 records - albeit - by having to scroll down vs “return all rows”.
But not able to group by supplier to work with the results.
Getting better, but not there.
Customer Tracker
CRM Calls
Shows the oldest first when looking at the grid view, summarized and clicking on the call.
Invoices and Shipments
Now showing the latest first in the grid view.
Getting close, but missing the critical CRM portion of the tracker, making Epicor not the top choice for CRM
Haven’t reviewed the issues in finance yet, selecting invoices to pay has been an issue not being able to easily select multiple invoices to pay.
Sounds like those buyers really don’t want their
moved!
Just to remind our readers, the cloud is a different model. You pay for what you use. As a general rule, cloud providers haven’t charged for bringing data into the cloud, but they do charge when you retrieve it. For those who host their Kinetic systems in the cloud, they are going to be more conscience of the costs. For those on SaaS, Epicor is including these charges in the subscription. This means if cloud subscribers are wasteful with resources, there may be a day where the subscription price goes up for all users or there might be a data cap on retrieval and an additional charge for usage over that amount.
Cloud Programmers managing resources:
On Prem programmers managing resources:
If these buyers were materials people, they would move a whole pallet of parts to the work center and return the ones they didn’t use - multiple times a day. ![]()
A more efficient model might be, first show me the suppliers that have suggestions, and then retrieve the suggestions on the supplier of interest. One could even add another layer where the number of suggestions for the supplier was returned by part, class, or material category, and then retrieve just those for processing.
Interesting. As a developer, I always have both .NET Framework 4.8 and .NET 6 on my machine and I haven’t run into this. But I don’t use LINQPad.
Is the issue limited to LINQPad? or have you experienced issues with the Kinetic client as well?
I think some folks experienced it when trying to compile a BPM on the Client PC in Epicor. But besides those 2 I haven’t had any issue with Visual Studio or anything.
If you have reproducible steps, it would be good to report the BPM use case through support so we can review.
@Mark_Wonsil I agree with you, but Epicor has not come up with a way to make this happen in Kinetic easily.
So, Classic will be the solution, until they come back with a better way.
@carlosqt found this blurb. It is atleast in the help file. Looks like Epicor is aware, of some subtle differences between the runtimes.
The doc is referring to a message that was in BPM during the preview releases. That message was removed but it looks like it was left in the docs. I’ll report this to our docs team.
If .NET 6 is installed on the client, BPM will leverage it to syntax check the code since BPMs eventually get compiled on the server. If it’s not installed, it will syntax check on .NET Framework. There are no known issues with this that I’m aware of.
No longer true on 2022.2! I was able to in place upgrade the appserver and clients with auto updater no issues. First time ever and I’ve tested that process probably since 10.2.400 to 500 are our company. Never realized before, but just found out if you update the version number of a custom package, just a single package, in the bottom of the sysconfig in deployment, it will only deploy that one custom package. We have used PDQ deploy previously, which also works but it’s nice to use the tools at hand.
@jgiese.wci Out of curiousity, do you have any information/notes you can share on the in place upgrade process between 2022.1 and 2022.2? I typically set up a new server between releases but this is not ideal and would be really cool if a less disruptive process works. I don’t enjoy reinstalling client software between releases
