Wow!!! never thought of that Sherlock
Of Gerry Loranger
Sent: Friday, 12 November 2010 12:30 AM
Subject: RE: [Vantage] Salesman deleting quotes-please help
Upgrade!
Behalf Of
Manasa Reddy
Sent: Thursday, November 11, 2010 8:48 AM
Gerry,
They don't have BPM in version 6.1!
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
<mailto:manasa%40weldcoa.com> <mailto:manasa@...
<mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Gerry Loranger
Sent: Thursday, November 11, 2010 7:13 AM
Sure, just create a BPM and Raise an exception on Delete. Here's how you
do
it:
1. Open System Management > Business Process Management > Method
Directives.
2. Click the Method Code button, set the business object to Quote,
click the Search button and double click Update from the list that
appears.
3. Click the Pre-Processing tab, click the Conditions button, select
Add Condition from the top left of the window.
4. From the User Text drop down list, select ?the specified field of
the changed row is equal to the specific value".
Click specified and select the QuoteNum field from the ttQuoteCom table.
Click "the changed row" and change it to "the deleted row"
Click "is equal to" and change it "is more than"
Click "specific" and enter 0.
Click OK.
5. Click the Actions button and select Add Action.
6. From the user text drop down list, select Raise Exception based on
the designed template. Enter some descriptive text like, "Quotes cannot
be
deleted".
7. Make sure you enable the Directive and give it a try.
Behalf Of
Mark Howard
Sent: Wednesday, November 10, 2010 6:30 PM
Subject: [Vantage] Salesman deleting quotes-please help
I have Salespeople rated on performace. 1 item is Quote hit rate.
I have discovery quotes are being deleted, I suspect a salesperson is
deleting quotes so his hit rate is better
Is there anyway I can find the delete quotes as they don't show in the
Audit log or change log
BTW Vantage 6.1
thanks in advance
Best regards,
Mark Howard
Financial Controller
P +61 7 3277 7499
D +61 7 3277 7499
F +61 7 3875 1887
M
E mhoward@... <mailto:mhoward%40jaws.com.au>
W www.jaws.com.au <http://www.jaws.com.au/>
Disclaimer:
This document (and any accompanying file attachments) is intended solely
for the use of the individual or entity to which it is addressed and
contains information that is personal, privileged, confidential or
exempt from disclosure. Any dissemination, or copying of this document
to anyone but the intended recipient is strictly prohibited. If you have
received this document in error, please notify the sender immediately by
email and destroy any copies of the message (including any accompanying
file attachments). Furthermore, we accept no responsibility for the
content of any email which is sent by an employee that is of a personal
nature. Thank you.
Of Gerry Loranger
Upgrade!
Behalf Of
Manasa Reddy
Gerry,
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Gerry Loranger
do
it:
Directives.
appears.
Click OK.
be
deleted".
Behalf Of
Mark Howard
BTW Vantage 6.1
thanks in advance
Best regards,
Mark Howard
P +61 7 3277 7499
D +61 7 3277 7499
F +61 7 3875 1887
M
Disclaimer:
nature. Thank you.
