Save data in InvcDtl after post
I do execute ABL code and then the execute code below option. I understand that forward to produce is faster and or the code is not compiled each time, but I have not gotten that down yet.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Bill Wu
Sent: Saturday, March 09, 2013 4:08 PM
Subject: [Vantage] RE: Save data in InvcDtl after post
This is what I'm looking for. I will try this. The updatable BAQ might work, but I'm dealing with several thousand rows. I take you place this code in the .p file and run this on the server? I can probably figure this out.
Thank you very much.
Bill Wu
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Greg Payne
Sent: Saturday, March 09, 2013 11:54 AM
Bill:
I would use a data directive which is not dependent on the method. The code would look something like below depending on the data that you want to put in the InvcDtl table.
Greg Payne
For each ttInvcDtl FIELDS(Company PartNum) where ttInvcDtl.RowMod = "A" no-lock.
For Each PartPlant fields( number01 ) no-lock where
PartPlant.Company = ttInvcDtl.Company and
PartPlant.Plant = ttInvcDtl.Plant and
PartPlant.PartNum = ttInvcDtl.PartNum.
Assign ttInvcDtl.Number01 = PartPlant.Number01.
End.
End.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Bill Wu
Sent: Friday, March 08, 2013 11:52 PM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Save data in InvcDtl after post
Hi! group,
I have a need to save some data into user defined fields in InvcDtl table. We have Progress database. E9 700C. I tried Epicor's ARinvoice adapter. It won't allow me do the update method for all Canadian transactions. I don't know 4GL, can someone help with some sample 4GL code to update existing posted invoice detail record?
Thanks in advance.
Bill Wu
THE INFORMATION CONTAINED IN THIS E-MAIL MESSAGE IS INTENDED ONLY FOR THE PERSONAL AND CONFIDENTIAL USE OF THE DESIGNATED RECIPIENT(S) NAMED ABOVE. IF THE READER OF THIS MESSAGE IS NOT THE INTENDED RECIPIENT OR AN AGENT RESPONSIBLE FOR DELIVERING IT TO THE INTENDED RECIPIENT, YOU ARE HEREBY NOTIFIED THAT YOU HAVE RECEIVED THIS DOCUMENT IN ERROR, AND THAT ANY REVIEW, DISSEMINATION, DISTRIBUTION, OR COPYING OF THIS MESSAGE IS STRICTLY PROHIBITED. IF YOU HAVE RECEIVED THIS COMMUNICATION IN ERROR, PLEASE NOTIFY US IMMEDIATELY BY RETURN E-MAIL OR TELEPHONE AT 585-494-1817.
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Hi! group,
Thanks in advance.
Bill Wu
You can use an Updatable ��Q
[Description: Description: Description: Description: cid:image002.png@01CDB5D2.96C69A10]
Stelios Zoumis <mailto:s.zoumis@...> | EBS - Enterprise Business Solutions | Sr Business Consultant |
Tel: +30 210 6874300 (ext. 314) | Fax: +30 210 6855564 | www.atc.gr<http://www.atc.gr/>
[Description: Description: Description: Description: cid:image009.jpg@01CDB5D2.96C69A10]<https://dunsregistered.dnb.com/DunsRegisteredProfileAnywhere.aspx?Key1=3100369&PaArea=email>
Sent: Saturday, March 09, 2013 6:52 AM
Hi! group,
Thanks in advance.
Bill Wu
Bill:
Greg Payne
End.
End.
Hi! group,
Thanks in advance.
Bill Wu
Bill Wu
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Greg Payne
Bill:
Greg Payne
End.
End.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Bill Wu
Hi! group,
Thanks in advance.
Bill Wu
