It looks like the timing is now the problem. I tried a newer scanner
that let me slow down the input and it works fine. So, since I can't
get the older scanners to scan any slower, I guess I'll have to
replace them?
--SF
--- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@...>
replace them?
--SF
wrote:
>you're
> Here's mine:
> "*" + Trim({OPENJOBS_VIEW.JobNum}) + "$I" +
> trim(totext({JobAsmbl.AssemblySeq},0)) + "$I" +
> trim(totext({JobOper.OprSeq},0)) + "$I" + "*"
> My issues were resolved when I reprogramed the scanners. It took
> quite a bit of trial and error but was able to get it to work.
> Do note my custom view "OpenJobs_View" (JobHeader filtered for open
> and released jobs at the Progress level) but you can substitute the
> JobAsmbl.JobNum or JobHead.JobNum just as well.
> Also, I don't understand the purpose of the replace function in your
> formula? Do you have asterisks in your job numbers? It seems that
> would be a major problem either way. What are the calculations
> using for the Assembly Seq and the Operation Seq? Why would youhave
> asterisks in either of those that you need to replace?the
> Finally if you haven't already done so, I would recommend putting a
> non-barcode font with the identical information in your report under
> the bar code to make sure you are getting want (at least temporarily
> until you get the bugs worked out).
> Best of luck.
> --- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@> wrote:
> > What is the proper format for a bar code if you want to include
> > job number - assembly - operation.assembly
> > Tab is the delimiter which is programmed as $I for our bar code
> > scanners.
> > Here is what were currently using, but it's stopping at the
> > number:
> > "*" + REPLACE(TRIM({JOBASMBL.JOBNUM}),"*","") + "$I" +
> > REPLACE(TRIM({JobAsmbl.Calc_BCAsmSeq}),"*","") + "$I" +
> > REPLACE(TRIM({JobOper.Calc_BCOprSeq}),"*","") + "$I" + "*"
> > Thanks,
> > --SF
