Search results pop into UltraGrid
Thanks Bernie,
Â
That worked beautifully.Â
Â
Ahmet
--- On Mon, 12/1/08, bw2868bond <bwalker@...> wrote:
Subject: [Vantage] Re: Search results pop into UltraGrid
Date: Monday, December 1, 2008, 3:19 PM
Try this: ugdEpiCustom1. DataSource = ds
(I am pretty sure the list lookup does not return UD05 table )
--- In vantage@yahoogroups .com, Ahmet Erispaha <ahmeterispaha@ ...>
wrote:
> [First off, Do not set a value for recselected - the search box
sets
> that value to let you know if it found anything.
> Â
> OK, changed btn click event handler to:
> Â
> Â Private Sub btnEpiCustom1_ Click(ByVal Sender As Object, ByVal Args
As System.EventArgs) Handles btnEpiCustom1. Click
> Â Â '// ** Place Event Handling Code Here **
> Â Â Â Â Â Â Â Dim recselected as Boolean
> Â Â Â Â Â Â Â Dim showsearch as Boolean = True
> Â Â Â Â Â Â Â Dim whereclause as String = ""
> Â Â Â Â Â Â Â Dim multirecords as Boolean = False
> Â Â Â Â Â Â Â dim ds as dataset = searchfunctions. listlookup
(otrans,"UD05Adapte r", recselected, showsearch, whereclause,
multirecords)
> Â Â Â Â Â Â Â ugdEpiCustom1. DataSource = ds.Tables("UD05" )
> Â End Sub
> [did you actually select some data in the search form and click the
OK
> button?]Â Â Yes.
> Â
> --- On Mon, 12/1/08, bw2868bond <bwalker@... > wrote:
> From: bw2868bond <bwalker@... >
> To: vantage@yahoogroups .com
> Date: Monday, December 1, 2008, 2:52 PM
> First off, Do not set a value for recselected - the search box sets
OK
> button?
> --- In vantage@yahoogroups .com, "ahmeterispaha"
> wrote:
> > I tried this with a custom UD05 Maintenance program hoping to get
a
> > better handle on how to work with the UltraGrid programmatically,
> but
> > my grid remained empty after selecting from the search -- no
column
> > headers, no data. Here's my code (which I put in a custom
button's
> > click event):
> > Args As System.EventArgs) Handles btnEpiCustom1. Click
> > Dim recselected as Boolean = True
> > multirecords)
> > End Sub
> > I didn't set the Datasource and Datafield properties in the
> > Customization Tools Dialog, expecting that the code above would
do
> > the necessary binding.
> > What am I doing wrong?
> > Ahmet
> > --- In vantage@yahoogroups .com, "Stephen Edginton" <stephene@>
> > wrote:
> > > ugdUltraGrid. DataSource = ds.Tables("SerialNo ")
> > > but that doesn't conform to the Epicor Framework (but will work)
> > > The better way to achieve this is to initiate an EpiDataView
and a
> > > DataView of the table.
> > > Then you can use notifications and the customization tool to
bind
> > the
> > > new EpiDataView to your grid - once added to the transaction.
> > > (That should point you in the right direction)
> > > Regards,
> > > Stephen
> > > From: vantage@yahoogroups .com
[mailto:vantage@ yahoogroups .com] On
> > Behalf
> > > Of dub554
> > > Sent: 10 September 2007 15:57
> > > Subject: [Vantage] Search results pop into UltraGrid
> > > I have code that opens up a search using the SerialNoAdapter.
> > > dim srlnum as dataset = searchfunctions. listlookup( otrans,
> > > "SerialNoAdapter" , recselected, showsearch, whereclause,
> > multirecords)
> > > I would like for all the results of this search to go into an
> > UltraGrid.
> > > Any suggestions?
> > > __
dim srlnum as dataset = searchfunctions.listlookup(otrans,
"SerialNoAdapter", recselected, showsearch, whereclause, multirecords)
I would like for all the results of this search to go into an UltraGrid.
Any suggestions?
ugdUltraGrid.DataSource = ds.Tables("SerialNo")
The better way to achieve this is to initiate an EpiDataView and a
Then you can use notifications and the customization tool to bind the
Regards,
Stephen
Of dub554
Any suggestions?
__
I tried this with a custom UD05 Maintenance program hoping to get a
better handle on how to work with the UltraGrid programmatically, but
my grid remained empty after selecting from the search -- no column
headers, no data. Here's my code (which I put in a custom button's
click event):
Private Sub btnEpiCustom1_Click(ByVal Sender As Object, ByVal
Args As System.EventArgs) Handles btnEpiCustom1.Click
dim ds as dataset = searchfunctions.listlookup
(otrans,"UD05Adapter", recselected, showsearch, whereclause,
multirecords)
ugdEpiCustom1.DataSource = ds.Tables("UD05")
End Sub
Customization Tools Dialog, expecting that the code above would do
Ahmet
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
the
> Regards,
> Stephen
Behalf
> Of dub554
multirecords)
UltraGrid.
> Any suggestions?
> __
did you actually select some data in the search form and click the OK
button?
--- In vantage@yahoogroups.com, "ahmeterispaha" <ahmeterispaha@...>
but
> click event):
> multirecords)
> End Sub
> Ahmet
> --- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@>
> the
> > Regards,
> > Stephen
> Behalf
> > Of dub554
> multirecords)
> UltraGrid.
> > Any suggestions?
> > __
[First off, Do not set a value for recselected - the search box sets
Â
Â
 Private Sub btnEpiCustom1_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnEpiCustom1.Click
       dim ds as dataset = searchfunctions.listlookup(otrans,"UD05Adapter", recselected, showsearch, whereclause, multirecords)
 End Sub
[did you actually select some data in the search form and click the OK
button?]Â Â Yes.
Â
button?
--- In vantage@yahoogroups .com, "ahmeterispaha" <ahmeterispaha@ ...>
but
> click event):
> multirecords)
> End Sub
> Ahmet
> the
> > Regards,
> > Stephen
> > From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
> Behalf
> > Of dub554
> multirecords)
> UltraGrid.
> > Any suggestions?
> > __
Try this: ugdEpiCustom1.DataSource = ds
--- In vantage@yahoogroups.com, Ahmet Erispaha <ahmeterispaha@...>
sets
> Â
> Â
> Â Private Sub btnEpiCustom1_Click(ByVal Sender As Object, ByVal Args
> Â Â Â Â Â Â Â dim ds as dataset = searchfunctions.listlookup
multirecords)
> Â Â Â Â Â Â Â ugdEpiCustom1.DataSource = ds.Tables("UD05")
> Â End Sub
OK
> button?]Â Â Yes.
> Â
> From: bw2868bond <bwalker@...>
OK
> button?
a
> but
column
button's
> > click event):
> > multirecords)
> > End Sub
do
> > Ahmet
and a
bind
> > the
> > > Regards,
> > > Stephen
> > Behalf
> > > Of dub554
> > multirecords)
> > UltraGrid.
> > > Any suggestions?
> > > __
