Sequence Function Ice.IceContext
Anyone have any ideas on the best way to get a new sequence from an Epicor function?
In a recent thread, Jose recommended to use code like this in a BPM to get a new sequence:
// Bring in Ice.Lib.NextValue.dll
const string sequenceName = "InvcGrpIDAA";
var nextVal = new Ice.Lib.NextValue(Db);
int nextGroupID = nextVal.GetNextSequence(sequenceName);
I added a reference to Ice.Lib.NextValue.dll but cannot figure out how to pass in Db context. If I give the library access to read data by pulling in a table reference to a random table, this.Db is available but it seems to be of a different type. I get the following error:
Argument 1: cannot convert from 'EFx.MyFunction.Implementation.ILibraryContext' to 'Ice.IceContext'
Any help or thoughts are appreciated
The Db object does not exist in functions until you add a table as a reference,
and then, the context is limited.
I am unsure if the limited Db context will work, but let’s find out.
If it does not, you can make a new one, but then it’s real easy to break the security model
for functions lol.
Edit: Half of that was in your post lol
Thanks for the quick response. Out of curiousity, how do I spin up a new one or is that secret sauce
I’ll share the secret sauce. It’s not exactly a secret, just one of those things you need to be careful
with, as you could very easily do things that are not recommended.
Screenshot 2023-06-28 102802
:rofl:
ErpContext dbContext = new ErpContext();
var nextVal = new Ice.Lib.NextValue(dbContext);
//This is just the output of my function
output = nextGroupID.ToString();
If you want to make @Mark_Wonsil happy, we can just build this into a UBAQ and call that.
It would be nice if GetNextSequence was a bonafide service where you just passed in a key. :person_shrugging:
Well, in the meantime, this is so easy, I’ll make a proper function and share it.
Thanks to @josecgomez for pointing it out and @timshuwy for showing us the way.
If you are going to instanciate your own context at least use the context factory service
var Dbcontext = Ice.Services.ContextFactory.CreateContext(); //Ice Context
//or
var Dbcontext =Ice.Services.ContextFactory.CreateContext<ErpContext>(); //ERP Context
paper bag GIF
So something like this?
using(var dbContext = Ice.Services.ContextFactory.CreateContext<ErpContext>())
  int nextNum = nextVal.GetNextSequence("MySequence");
  this.outNextVal = string.Format("{0:00000000}.xml",nextNum); //Ice.SysSequence table
Yes, better :slight_smile:
Function:
https://www.epiusers.help/t/lets-share-useful-functions-sharing-is-caring/100371/23
