Server log - large growth
Fathom is great. Saves me headaches daily. I just had a user run a report for every job in the system ( 3x ) and then when it took too long just killed Epicor and left it using all memory in the server.
I saw the memory and cpu buildup, checked the user and process, so I didn’t accidently kill an accounting user doing a Capture and then killed off his processes.
Sent: Wednesday, June 29, 2016 2:01 PM
Subject: RE: [Vantage] Server log - large growth
We see the hung report in system monitor and have cancelled it.  We’re not sure what caused the report to be hung up with those error messages in the log.  We do not use fathom.
Sent: Wednesday, June 29, 2016 11:03 AM
Do you use fathom to monitor your appservers? http://localhost:9090/fathom.htm
If I have a long running process I will see it in the server pool control list. The last change column should always be current when you click refresh at the bottom of the page.
Or in system monitor, check actions .. display all tasks and see if the report is listed there.
Sent: Wednesday, June 29, 2016 11:42 AM
LTFViewer is able to view the log file but it’s been over an hour and has been loading 8 million lines so far.  It seems like a rogue BAQ report is generating a lot of the “xabaqrptxml.p …. X-NODEREF or X-DOCUMENT CREATE-NODE got an error:” messages.
Sent: Tuesday, June 28, 2016 5:23 PM
I use LTFViewer to read my log files. It will open large files and you can refresh to see the last lines in the logs.
Maybe you can see what is being logged and stop just that process.
http://www.softpedia.com/get/Office-tools/Other-Office-Tools/Large-Text-File-Viewer.shtml#download
From: vantage@yahoogroups.com [ma ilto:vantage@yahoogroups.com]
Sent: Tuesday, June 28, 2016 5:44 PM
There are financial processes that are currently being run such as posting and inventory WIP reports that causes issues if we restart the task agent.  We restart the appservers once a month.
From: va ntage@yahoogroups.com [mailto:vantage@yahoogroups.com]
Sent: Tuesday, June 28, 2016 4:32 PM
You can stop the task server w/o having any users aware. I use the file threshold size and number of log files to keep the logs under 40MB each.
How often do you restart the appservers?
Sent: Tuesday, June 28, 2016 3:40 PM
Subject: [Vantage] Server log - large growth
Our task agent server log is currently at 2GB and we are experiencing performance issues.  We are not able to rename or create a new log and the log file won’t allow us to open it due to its size.  An yone know what can be done with a 2GB log that is locked due to being in use without having to shut down and restart the task agent?
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileg ed and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
"This (docu ment/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
The information contained in this communication, including att achments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemi nation, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
The information contained in this communication, including attachments, is privileged and confidential. It is intended onl y for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
Our task agent server log is currently at 2GB and we are experiencing performance issues.  We are not able to rename or create a new log and the log file won’t allow us to open it due to its size.  Anyone know what can be done with a 2GB log that is locked due to being in use without having to shut down and restart the task agent?
I took a look at my Task log and since the 18th of Jun, the file is only 160Kb.  My settings: http://imgur.com/dnVmIuQ
I don’t think I have ever had an issue with the TaskAgent log that I don’t even have a threshold on mine.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Tuesday, June 28, 2016 2:44 PM
To:
To:
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
The information contained in this communication, including att achments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
