Hi
Â
We have tried that.
Â
We have our Apps/Dbs all stopping and starting on a night to sort other errors, and generally the PID that is locked on CPU is not visible in the logs and the PID that started it in the logs has been closed by stopping and starting the apps and db and the PID that is running in task manager is not available in Progress Explorer Tools PIDS.
Â
Any other info would be appreciated.
Sent: Monday, 2 April 2012, 13:35
Subject: RE: [Vantage] Re: Server Specs
Â
You can find out what those processes are doing when they peg at 13%, that
usually means they are using a full core from a total of 8 processor cores?
First you should check your System Monitor to see what is going on, if it's
a report or specifically run process, it will be noted there. The next step
is to make sure your main appserver logs are set to verbose, and then you
can actually look up the PID and get an answer as to what that PID is
actually doing based on the last actions called by it.
Chris Thompson
Sent: Monday, April 02, 2012 4:39 AM
Subject: Re: [Vantage] Re: Server Specs
Hi
Â
We have no scheduling other than global alerts.
Â
It has been an issue since we went live with epicor.
Â
Peicor have looked into all kinds of things including licenceing etc.
Â
Nothing has done the trick.
Â
Sometimes we get PIDs for Apps that stick at 13% CPU.
Â
All logs are fine.
Â
Strange
Sent: Friday, 30 March 2012, 14:04
If you're having issues with people being unable to login or apps hanging, I
would suggest that there may be more than just performance issues here.
I would try to figure out what is preventing the logins first. If you've got
custom code building sessions or an incorrectly scheduled process that is
tying up your app servers that could cause this type of scenario.
Obviously you know your system/situation better than I do, but I'd be pretty
hesitant to attribute stability issues to performance.
On Fri, Mar 30, 2012 at 3:13 AM, Chris Thompson
<chriselectrix@...>wrote:
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
Â
We have tried that.
Â
Â
Â
Chris Thompson
Hi
Â
Â
Â
Â
Â
Â
All logs are fine.
Â
Strange
> Are you Progress or SQL?
> Maybe the performance of our legacy system was so good it makes
> everything look poor.
> We are constantly having issues with users not being able to log in,
> or apps that wont stop.
> Plus things like Inventory WIP report take 4-6 hours to run for a month.
> From: John Driggers <waffqle@...>
> Sent: Thursday, 29 March 2012, 17:57
> I've got a 4 socket, 32gb box with 8 SSD that I bought from Dell for
> about that price.
> That said, we split it between Epicor and a terminal server and have
> no real performance issues.
> On Thu, Mar 29, 2012 at 12:06 PM, John Kreger <lilj8069@...> wrote:
> > I built our production and backup server from scratch for around
> > $7000 a piece. We've really had no issues on 9.05.607b currently.
> > Here's a copy
> of
> > our specs for your perusal:
> > Component Qty Item Model Number Price Total Processor 2 Intel Xeon
> > 2.93 GHz Processor Intel X5570 $1,399 $2,798 Motherboard 1 Intel
> > Server Board Intel S5520URT $518 $518 RAM 2 OCZ Gold DDR3-1333Mhz
> > Memory 12GB OCZ3G1600LV12GS $215 $430 Case 1 Chenbro 3U General
> > Purpose Server Chassis Chenbro RM31408T-ET $685 $685
> > 8 Hot Swap drive bays, 650w redundant power supply
> > Storage Controller 1 PCI-Express x8 SAS 8 port Intel RSBL080DE $650
> > $650 Storage
> > RAID 10 8 15K.6 146GB 15000 RPM 16MB Cache SAS 3Gb/s Seagate
> > ST3146356SS
> > $170 $1,360 CD/DVD R/W 1 Sony Optiarc Black 24X DVD-R/RW Sony
> > AD-7240S-0B
> > $20 $20 Riser Card 1 Intel SR2600/2625 5 Slot PCI-E Active Riser
> > Intel ASR26XXFHLPR $76 $76
> > Total $6,537
> > With what I know now, the only change I would make would be to SSD's
> > as
> the
> > data access speed seems to be our only bottleneck. I've also added a
> > 4
> port
> > Intel fiber network card and use the on-board dual NIC's as a fail-over.
> > MRP, scheduling, and most other processes run in mere minutes overnight.
> > We've never had login issues. I know alot of people are skeptical of
> > self built machines but it really got us a huge savings compared to
> > going with DELL or HP.
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
> have already linked your email address to a yahoo id to enable access.
> and Crystal Reports and other 'goodies', please goto:
>Â
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
