Service Connect
What are you planning to do with it?
Service connect is basically a workflow tool that allows you to stitch together business logic in a series of I/O to create custom solutions.
Pros: useful for processing repetitive data entry routines, importing/exporting data, integrating data with other products
Cons: steep learning curve/fairly complex, little documentation, cumbersome task monitor and error processing, not very user-friendly, the educational resources are really light (you will have to dig in and make it happen, or hire someone)
I know a number of people who purchased it and never use it. Mostly because of the items I listed in the Cons.
However, if you can get through the complexity of it, and understand the business logic / method implementation AND XML piece of it, it can be quite useful and powerful. It has been a useful tool for me.
A final note: there are often other ways to accomplish the same thing instead of using Service Connect. You can use the DMT solution for data updates, or advanced BPM's, customizations, etc.
HTH,
Ross
