Service Connect
Is there a linux version of service connect? I am just curious.
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 295 or 870-480-4530
Fax: 870-423-3568
Web Site: http://www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
Yup. It's called Perl.
Not that I know of.
Of Matt Caldwell
Sent: Thursday, July 09, 2009 12:16 PM
Subject: [Vantage] Service Connect
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
I had a similar problem.
It turned out that I wasn't using the latest version of WS-Configuration.
Once I copied the latest WS-Configuration files (Including MfgSrvsPckg.zip / ICSharptCode.SharpZipLib.dll) from the Progress server machine to my service connect / information worker server, it worked.
--- In vantage@yahoogroups.com, Charles Carden <ccarden@...> wrote:
> I am running Service Connect on 8.03.405a. There should be no need to copy anything from the Vantage Server to the Service Connect folder. This is the method that I used when I upgraded.
> 1. Installed 8.03.405a Vantage service Pack.
> 2. Updated Web Services on the Vantage Server using WSConfig.
> 3. Re-imported Web References on the Service Connect server.
> There should not be any other necessary procedures. We also have Service Connect on a different server than Vantage.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of wamitch1012
> Sent: Tuesday, August 19, 2008 7:49 AM
> Subject: [Vantage] Re: Service Connect
> Yes, Service Connect and Vantage are installed on separate win 2003
> servers and WSE3 is installed on the Service Connect machine.
> The web services are installed on the Vantage server but the service
> pack documentation advised copying them on to the Service Connect
> server for some reason.
> I've just tried reinstalling again and its still failing so I may try
> having a look in that zip file next.
> Thanks
> WAM
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Stephen Edginton" <stephene@>
> wrote:
> > So you have Service connect installed on a separate server.
> > Are the Web services installed on the vantage server or the service
> > connect server?
> > i.e. where do your web methods point to?
> > Do you have WSE 3 installed on that server?
> > If you run IIS you should be able to identify the virtual directory
> used
> > and hence where the dll's are located.
> > You could then extract from the MfgSrvsPckg.zip the updated files
> if you
> > cant get WSE 3 and hence WS configuration working.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
> Behalf
> > Of wamitch1012
> > Sent: 19 August 2008 11:44
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Already tried that...
> > If I do it on the Vantage server it process without an error, yet
> > when I go to do a workflow it again flags up the version mismatch.
> > The documentation tells you to copy the web services directory from
> > the Vantage server to the Service Connect server - but doesn't tell
> > you precisely where - so I copied it to Program Files\Epicor
> Service
> > Connect. Running ws-config from there gives me "Microsoft Web
> > Services Enhancements 3.0 does not seem to be installed. Cannot
> > continue". I believe this is related to a 64 bit windows server
> > issue, however the server this is running on is 2003 32 bit.
> > WAM
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
> > wrote:
> > > You will have to update the webservices
> > > Use WS-Configuration to update them.
> > > Regards,
> > > Stephen
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%
> 40yahoogroups.com> ] On
> > Behalf
> > > Of wamitch1012
> > > Sent: 19 August 2008 11:16
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > Is there anyone out there who has experience of Service Connect
> and
> > can
> > > advise on a small problem I'm having using it following on from
> > > applying the 405 Service Pack ?
> > > The service pack was successfully applied to the Vantage Server,
> > > however when I started running data imports using Service Connect
> > the
> > > Service Connect admin console started reporting errors - Version
> > > mismatch between client (404) and server (405) - and nothing is
> > > imported.
> > > I have checked IIS and its running the .net framework 2.0.
> > > To say the documentation on this service pack is ambiguous on the
> > > subject of Service Connect is putting it very mildly.
> > > I'm aware that theres a patch for this service pack but I'd
> prefer
> > to
> > > get everything up to the same level before applying it.
> > > Thanks in advance for any/all helpful suggestions.
> > > WAM
> DISCLAIMER:
> This e-mail, including attachments, may include confidential and/or proprietary information, and may be used only by the person or entity to which it is addressed. If the reader of this e-mail is not the intended recipient or his or her authorized agent, the reader is hereby notified that any dissemination, distribution or copying of this e-mail is prohibited. If you have received this e-mail in error, please notify the sender by replying to this message and delete this e-mail immediately.
Loop1 (parent loop)
=>child 1
=>child 2
=>child 3
In service connect, is there a way to take the above child data, and
concatenate it in some way so that I don't have to loop through the
nodes in a sub-workflow? I want to join the 3 child nodes together into
a single field in my order header.
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
I'm developing a SC to import BOMs. PartService works great. I can create the top level assembly and revision without fail. I'm having problems with the EngWorkBenchService. When I try to create a new ECO SC fails with "Invalid User ID or Password".
I _can_ create and process ECOs from within Epicor itself. I'm not sure what user or password is invalid.
Help?
Likely you need to reimport your web service in Service Connect and use
a valid user name and password for Vantage
Of Aaron
Sent: Friday, February 05, 2010 9:45 AM
Help?
I'd try admin/admin, or just admin with no password.
cooner_55421
Sent: Wednesday, January 12, 2011 11:32 AM
Hi,
I saw that Service Connect is installed on a Vantage Server here.
The people who would have installed this are long gone.
When I tried to launch the the workflow designer, it asked for a password.
Is there a default password or a way to reset it?
Wondering how old this version be - 8.1.0.3250, if it will work.
And, if you have this version and have a current maintenance plan, you
can probably get a newer version downloaded from Epicor site.
Of Kevin Simon
Sent: Wednesday, January 12, 2011 11:03 AM
Subject: RE: [Vantage] Service Connect
Behalf Of
cooner_55421
Hi,
password.
Service Connect's default user name is admin. There is no password.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Kevin Simon
Sent: Wednesday, January 12, 2011 12:03 PM
Behalf Of
cooner_55421
Hi,
password.
admin without a password
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of cooner_55421
Hi,
password.
Has anyone seen this error message before in service connect? It looks like the service connect server is not able to communicate with the App server. "Unable to connect to the AppServer."
Error Message:
<msg:req tag="PartService.Update">
<msg:ers>
<msg:error type="unexpected error">
<msg:number>2147220990</msg:number>
<msg:description>Error in the application.</msg:description>
<msg:source>Client Proxy error occurred when calling PartService.Update
Exception of type System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Unable to connect to the AppServer.
Details:
Could not connect to the AppServer: General Error: The requested name is valid, but no data of the requested type was found. (7203)
at Epicor.Mfg.WS.Services.PartService.Update(String CompanyID, XmlNode PartData, Boolean continueProcessingOnError, Boolean& errorsOccurred, XmlNode callContextIn, XmlNode& callContextOut)
SOAP exception information
Code: http://schemas.xmlsoap.org/soap/envelope/:ServerActor: Details: <detail /></msg:source>
</msg:error>
<msg:description>Exception of type System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Unable to connect to the AppServer.
Details:
at Epicor.Mfg.WS.Services.PartService.Update(String CompanyID, XmlNode PartData, Boolean continueProcessingOnError, Boolean& errorsOccurred, XmlNode callContextIn, XmlNode& callContextOut)</msg:description>
<msg:source/>
</msg:error>
Thank you for your help,
Flynt Moreland
Did you make sure the values you passed into SC were the correct format
and you passed the correct company info and you have the web services
logged in with the correct user rights?
Christopher W. Marsch
IT/Database Administrator
Mechanical Dynamics & Analysis, Ltd.
19E British American Blvd.
Latham, NY 12110
(518) 399-3616 x272
Cell: (518) 795-0200
Of flyntm
Sent: Tuesday, September 13, 2011 4:22 PM
Error Message:
<msg:ers>
AppServer.
Details:
</msg:error>
AppServer.
Details:
<msg:source/>
</msg:error>
Flynt Moreland
Flynt,
I'd recommend you check to make sure you're connecting to the correct
database. It sounds as if the app servers are down, perhaps the web
services is pointing to something you're not expecting. Open up the web
services configuration, check with server/port you're connecting to. My
guess is that the one that it's actually trying to use is down.
Kevin Simon
Marsch, Chris
Sent: Tuesday, September 13, 2011 4:26 PM
Latham, NY 12110
(518) 399-3616 x272
Behalf
Of flyntm
Error Message:
<msg:ers>
AppServer.
Details:
</msg:error>
AppServer.
Details:
<msg:source/>
</msg:error>
Flynt Moreland
It turned out that the problem was that PARTSERVICE was not imported/installed in the database we were using under WEBSERVICES. Also the MANAGER password had to be changed in Service Connect because it was using its original login credentials that was used when it was installed. Something to keep in mind when changing the MANAGER password.
Thanks for the help.
Flynt Moreland
We are considering getting service connect.
for those who have it already, what are the pros and cons of it?
It is best if it is on a dedicated server for resource purposes. It is great for complex imports, data and process automation and for integrating 3rd party products. It is great for exporting data as well. The cons are it takes a while to learn the product. To use it you really need to know the tables, fields, and the business objects and methods. You also have to have to learn how to read trace files. Service Connect is a great tool as long as you have the time to dedicate to developing the workflows and learning the product.
Latham, NY 12110
(518) 399-3616 x272
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of supertico05
Sent: Wednesday, June 26, 2013 1:49 PM
Chris said it all perfectly.
I'd like to underscore his "time to dedicate" comment. It's unlike any
other programming interface I've seen in my career. It's a powerful tool
and with that comes a steep learning curve.
I never did learn it just because of that learning curve; it humbles you.
I've been told that folks without much programming knowledge pick it up
easier than others who may have extensive coding in their background.
I have ultimately abandoned SC and carefully wrote SQL stored proc's and
triggers to do what I needed Service Connect to do. I've been using SQL
varieties for 20+ years, so it's like riding a bike for me. To me, Service
Connect is like landing the space shuttle with one arm tied behind your back
while someone sprays salt water in your eyes and shouts Russian expletives
at you.
Marsch, Chris
Sent: Wednesday, June 26, 2013 2:00 PM
product.
Latham, NY 12110
(518) 399-3616 x272
What are you planning to do with it?
Service connect is basically a workflow tool that allows you to stitch together business logic in a series of I/O to create custom solutions.
Pros: useful for processing repetitive data entry routines, importing/exporting data, integrating data with other products
Cons: steep learning curve/fairly complex, little documentation, cumbersome task monitor and error processing, not very user-friendly, the educational resources are really light (you will have to dig in and make it happen, or hire someone)
I know a number of people who purchased it and never use it. Mostly because of the items I listed in the Cons.
However, if you can get through the complexity of it, and understand the business logic / method implementation AND XML piece of it, it can be quite useful and powerful. It has been a useful tool for me.
A final note: there are often other ways to accomplish the same thing instead of using Service Connect. You can use the DMT solution for data updates, or advanced BPM's, customizations, etc.
HTH,
Ross
For now we are thinking of using it for:
Have our suppliers load a csv files with all of their promise dates to our POs to our ftp site. Then have service connect read that file and automatically load promise dates and comments to each PO.
We have over 2,000 PO releases open at any given time.
When a new blue print (or other document) is received from the customer, we save those in a specific folder in our server based on part number. We want service connect to notify us when a new drawing is added to the server, where the revision does not match the partrev.revisionnum field for the approved revision for that part number. Also automatically email our vendors that need that document, the latest revision.
What other helpful processes has anyone done with service connect?
Marco Vissuet
Systems Engineer
Pacific Contours Corporation
Cell (619)507-2311
Anaheim Office (714) 693-1260
San Diego Office (619)670-3900
Fax (714) 693-1252
mvissuet@...<mailto:marcov@...>
http://www.pacificcontours.com/
"The information contained herein may be subject to the International Traffic in Arms Regulations (ITAR) Warning: - This document contains data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.) as amended, or the Export Administration Act (Title 50, U.S.C., App 2401 et seq.) as amended. Violations of these export laws are subject to severe criminal and civil penalties. Disseminate in accordance with provisions of DoD Directive 5230.25.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of rossh777
Sent: Wednesday, June 26, 2013 11:16 AM
HTH,
Ross
WE use Service Connect for:
Sales order imports
Mass customer, Ship To, and Part updates
Create RMA's from a csv file
Import EDI orders via an XML file from our VAN
Mass part adjustments
Mass part transfers
Create new parts
Create new internal part cross references
I/we use it quite a bit...
--Matt Caldwell
> Marco Vissuet
> Systems Engineer
> Cell (619)507-2311
> Fax (714) 693-1252
> HTH,
> Ross
