So you have Service connect installed on a separate server.
Are the Web services installed on the vantage server or the service
connect server?
i.e. where do your web methods point to?
Do you have WSE 3 installed on that server?
If you run IIS you should be able to identify the virtual directory used
and hence where the dll's are located.
You could then extract from the MfgSrvsPckg.zip the updated files if you
cant get WSE 3 and hence WS configuration working.
Of wamitch1012
Sent: 19 August 2008 11:44
Subject: [Vantage] Re: Service Connect
Already tried that...
If I do it on the Vantage server it process without an error, yet
when I go to do a workflow it again flags up the version mismatch.
The documentation tells you to copy the web services directory from
the Vantage server to the Service Connect server - but doesn't tell
you precisely where - so I copied it to Program Files\Epicor Service
Connect. Running ws-config from there gives me "Microsoft Web
Services Enhancements 3.0 does not seem to be installed. Cannot
continue". I believe this is related to a 64 bit windows server
issue, however the server this is running on is 2003 32 bit.
WAM
"Stephen Edginton" <stephene@...>
wrote:
Behalf
connect server?
Of wamitch1012
WAM
wrote:
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> You will have to update the webservices
> Use WS-Configuration to update them.
> Regards,
> Stephen
Behalf
> Of wamitch1012can
> Sent: 19 August 2008 11:16
> Subject: [Vantage] Service Connect
> Is there anyone out there who has experience of Service Connect and
> advise on a small problem I'm having using it following on fromthe
> applying the 405 Service Pack ?
> The service pack was successfully applied to the Vantage Server,
> however when I started running data imports using Service Connect
> Service Connect admin console started reporting errors - Versionto
> mismatch between client (404) and server (405) - and nothing is
> imported.
> I have checked IIS and its running the .net framework 2.0.
> To say the documentation on this service pack is ambiguous on the
> subject of Service Connect is putting it very mildly.
> I'm aware that theres a patch for this service pack but I'd prefer
> get everything up to the same level before applying it.[Non-text portions of this message have been removed]
> Thanks in advance for any/all helpful suggestions.
> WAM
