Does anyone know how to get a customized Memo form on project entry to load? I was under the impression that naming it the same as the parent project entry customization would do the trick, but it seems I am mistaken.
That’s the trick. Another option might be with process calling maintenance.
Yep, to customize the memo I created a new process menu item and customized that, then used processing calling maintenance to call that custom menu item
When calling this process were you able to use the existing tool key and actions menu?
Yes, that’s what the process calling maintenance would perform.
I’m a dumby. I was thinking of the C# process caller and completely forgot about Process Calling Maintenance.
Thanks for the guidance guys!
