Simple BPM - Quantity Adjustment
I see a significant performance problem with the way you have the query assembled… you have linked the ds.inventoryQtyAdj table (which is not really a table but is a memory resident dataset) to a real dataset. The problem is that when SQL gets this, it doesnt run efficiently. Instead, you should get the data from the QtyAdj and put them into variables, and then FILTER PartTran’s criteria with those variables… see this rather large discussion: BPM SPEED Helpful Hint - be careful how you "Join"
