Slow moving stocks v4
Olwyn
Attached is a rough report that gives a weighted aging factor. Older
parts have a heavier weighting. I tried using last stock transaction
and found that if we sold one last week the other fifty in sock
became current.
The report is still being developed so it doesn't hanlde negative
quantities and quantity adjustments. The basic idea is to use
future/present value formulas as if the parts are accuring interest
and divide by the real amount. Spot checks indicate it is accurate.
For the list. I tried to post this in the file area and could not
access it. I can email it off list if you're interested.
RRD
On 12 Jan 2002 at 9:55, Olwyn Emery wrote:
> Hi All
> Does anyone have experience with reports for slow moving stocks on v4.
> Ideally I am trying to simply find any part that hasn't had a MFG-CUS
> or
> STK-CUS or STK-MFG for 6 months (regardless of other transactions ie
> moving
> from bin to bin or count adjustments). I have tried various
> calculations
> from parttran but clearly haven't got it right. Can anyone share any
> ideas
> or even a similar report I can use as a starting point.
> Any help would be greatly appreciated
> Thanks in anticipation
> Olwyn Emery
> Hallam Plastics (UK)
Russ Dover
IS Manager
Weaver Industries, Inc.
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
The following section of this message contains a file attachment
prepared for transmission using the Internet MIME message format.
If you are using Pegasus Mail, or any another MIME-compliant system,
you should be able to save it or view it from within your mailer.
If you cannot, please ask your system administrator for assistance.
---- File information -----------
File: FGAging.PRL
Date: 14 Jan 2002, 11:06
Type: Unknown
Hi All
Ideally I am trying to simply find any part that hasn't had a MFG-CUS or
STK-CUS or STK-MFG for 6 months (regardless of other transactions ie moving
from bin to bin or count adjustments). I have tried various calculations
from parttran but clearly haven't got it right. Can anyone share any ideas
Olwyn Emery
Mike, This sounds like a great report. Would you mind uploading it to the
files section.
Sent: Saturday, January 12, 2002 12:42 PM
To: vantage@yahoogroups.com; vantage@yahoogroups.com
Subject: Re:[Vantage] Slow moving stocks v4
This is something I developed in Crystal. The main report is basically a
"stock
status" looking at ParBin only for total onhands. I then use a Subreport
(why I
love Crystal!) that looks at the PartTran table. I filter this subreport to
only include relevant transaction types (for us STK-CUS, STK-MTL) grouped by
part. I then add a summary field to this group that is the "Maximum" of the
TranDate which gives me the last transaction date for that part. The days
or
aging is calculated by subtracting the max trandate from the printdate. I
then
pass this number to the main report.
When I run the report I export to Excel so that I can sort by highest days
so
that the obsolete inventory and it's value are at the top of the list.
Hope this helps!
Mike Lowe
Connor Manufacturing Services
____________________Reply Separator____________________
Subject: [Vantage] Slow moving stocks v4
Author: <vantage@yahoogroups.com>
Date: 1/12/02 9:55 AM
Hi All
Olwyn Emery
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=219350.1833377.3346791.1269402/D=egroupweb/S=17050071
83:HM/A=935577/R=0/*http://www.gotomypc.com/u/tr/yh/grp/300_06/g22lp?Target=
mm/g22lp.tmpl>
<http://us.adserver.yahoo.com/l?M=219350.1833377.3346791.1269402/D=egroupmai
l/S=1705007183:HM/A=935577/rand=784479231>
