Slow Performance in Job Tracker
At 11:41 AM 9/13/2001 , you wrote:
>One problem that we have run into is that when I select the Job tab in the
>Lot Tracker, both my system and the server slow to a crawl for about five
>minutes before any information appears in the window. This happens every
If you loaded everything per the instructions, but haven't done any DB
tweaking, then Progress is running [crawling?] with almost zero memory
caching. This document at EraNet has really good tuning instructions:
http://eranet.epicor.com/ansbook/vantage/public/1/13/130/1304mps.htm
Or as a quick fix, edit epic50\progress\startup.pf and add a -B
parameter. -B 10000 will give you about 40MB cache; enough for it to get
out of its own way, at least.
-Wayne
We have just put an install of Vantage 5 on a test server. I converted a
backup of our 4.0 database and we have been looking over the new version.
time I try it.
I have since installed the latest Progress and Vantage patches, but it
didn't help. Has anyone had this happen to them? Any ideas would be
appreciated.
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
