Thanks for the reply.
The change was prompted by the need for accurate cost centers. We are
trying to calculate an accurate burden for each machine. To pass these
accurate costs to a job we needed to use split burden rather then burden
=labor.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Tuesday, January 21, 2003 10:26 AM
To: vantage@yahoogroups.com; Vantage@yahoogroups.com
Subject: Re:[Vantage] Split Burden
First I assume that in your shop Labor is your primary driver? We
encountered
an issue where trying to use Labor=Burden did not work at all. There was a
major inconsistency with how Vantage calculated the standard costs for a
part
vs. how the job costs were calculated. Was this what prompted your change?
I
was ready to make a big deal out of it 18 months ago but apparently there
are
not many Vantage users with assembly shops that have more bodies than
machines
(wait until they expand into China!).
Anyway, I can think of two possible work arounds for you.
1) Make burden zero and only use labor. This way, the system will
calculate
the correct costs for you.
2) Have a general (area) burden instead of a calculated 'person' burden. It
will never be 100% accurate but everything will wash out at the end of the
month.
And I'm only on my first cup of coffee!
Mike Lowe
Connor Manufacturing Services
____________________Reply Separator____________________
Subject: [Vantage] Split Burden
Author: <vantage@yahoogroups.com>
Date: 1/21/03 7:28 AM
Hello all. We could use some help with this one.
On 01/01/03 we made the move to machine hours from labor hours in all of our
methods. We also changed our costing to be Split burden rather that
Labor=Burden so that the cost centers would be correct. We are now faced
with a problem. If two employees are clocked into the same job and several
other jobs at the same time it doesn't split the burden between the
jobs/employees correctly. It will split the burden between the employees
but doesn't consider if there is more then one job being ran on that work
center. Unfortunately for us, it is more common then not that more then one
job is being processed in a work center at the same time.
For example.
Work center XYZ
Employee 1 and Employee 2 both clock into two jobs at the same time on the
same work center and they work on these two jobs for one hour we get the
following results:
Labor
Employee 1 Labor for Job A is 30min
Employee 1 Labor for Job B is 30min
Employee 2 Labor for Job A is 30min
Employee 2 Labor for Job B is 30min
Total Labor hours is 2. This is correct.
Burden
Employee 1 Burden for Job A is 30min
Employee 1 Burden for Job B is 30min
Employee 2 Burden for Job A is 30min
Employee 2 Burden for Job B is 30min
Total Burden is 2 machine hours.
Total Burden should be 1 machine hour. The Burden should be distributed
among all jobs and employees using that work center. In reality, the
machine only ran one hour.
Are we doing something wrong our is there a workaround?
Thanks for the help.
Jeremy Leonard
IT Manager
K-T Corporation
317-398-6684
Vantage 5.1
Received: from alv-web1.alvaka.net [207.213.32.80] by la-smtpg.connorms.com
(ccMail Link to SMTP R8.31.00.5)
; Tue, 21 Jan 2003 04:20:58 -0800
Return-Path:
<sentto-20369-37223-1043152112-MLowe=connorms.com@...>
Received: from n22.grp.scd.yahoo.com ([66.218.66.78])
by alv-web1.alvaka.net (NAVGW 2.5.1.12) with SMTP id M2003012104295706625
for <MLowe@...>; Tue, 21 Jan 2003 04:29:57 -0800
X-eGroups-Return:
Received: from [66.218.66.95] by n22.grp.scd.yahoo.com with NNFMP; 21 Jan
2003 12:28:32 -0000
X-Sender: JLeonard@...
X-Apparently-To: Vantage@yahoogroups.com
Received: (EGP: mail-8_2_3_0); 21 Jan 2003 12:28:32 -0000
Received: (qmail 74122 invoked from network); 21 Jan 2003 12:28:32 -0000
Received: from unknown (66.218.66.218)
by m7.grp.scd.yahoo.com with QMQP; 21 Jan 2003 12:28:32 -0000
Received: from unknown (HELO k-tsvr1.ktcorp.com) (204.180.44.123)
by mta3.grp.scd.yahoo.com with SMTP; 21 Jan 2003 12:28:31 -0000
Received: by k-tsvr1.ktcorp.com with Internet Mail Service (5.5.2653.19)
id <DK25NCDQ>; Tue, 21 Jan 2003 07:28:30 -0500
Message-ID: <198ABC1B94AA0643BE422EB1090237581791@...>
To: "'Vantage@yahoogroups.com'" <Vantage@yahoogroups.com>
X-Mailer: Internet Mail Service (5.5.2653.19)
X-Yahoo-Profile: sqlguy29in
MIME-Version: 1.0
Mailing-List: list vantage@yahoogroups.com; contact
vantage-owner@yahoogroups.com
Delivered-To: mailing list vantage@yahoogroups.com
Precedence: bulk
List-Unsubscribe: <mailto:vantage-unsubscribe@yahoogroups.com>
Date: Tue, 21 Jan 2003 07:28:29 -0500
Reply-To: vantage@yahoogroups.com
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
=labor.
Jeremy Leonard
IT Manager
K-T Corporation
encountered
part
I
are
machines
calculate
month.
Mike Lowe
For example.
Work center XYZ
following results:
Labor
Burden
Jeremy Leonard
IT Manager
K-T Corporation
317-398-6684
Vantage 5.1
Return-Path:
X-eGroups-Return:
2003 12:28:32 -0000
MIME-Version: 1.0
Precedence: bulk
