I’ve reported this already to Epicor, but thought maybe would be good to share.
We were upgraded to 2024.1.8
Any report style I change after last nights upgrade will not print, even with the smallest update
Gives this error
System.IO.InvalidDataException: End of Central Directory record could not be found.
at System.IO.Compression.ZipArchive.ReadEndOfCentralDirectory()
at System.IO.Compression.ZipArchive..ctor(Stream stream, ZipArchiveMode mode, Boolean leaveOpen, Encoding entryNameEncoding)
at System.IO.Compression.ZipArchive..ctor(Stream stream, ZipArchiveMode mode)
at Ice.Core.SsrsReporting.ReportProcessorBase.DeployReportIfNeeded(String printProgram, String fullReportPath, SsrsConfigurationInformation configurationInfo, Func`1 reportingServiceCreator) in ```
Uploading same report style to Production which is not yet upgraded and printing works fine
This problem started for us yesterday when Cloud team upgraded our Third environment to 2024.1.8. They have stated it’s a known problem linked to Problem Number: PRB0284786
I am told that it is only affecting a subset of cloud hosted servers due to a failed upgrade to which they didnt follow their normal upgrade process.
Lets just hope the solve this and don’t replicate when they update our live environment next week.
@klincecum Just got back to this…so Report Styles in Kinetic-Web appear to be zip files ??? … ugh … now more steps in the process … I gotta download, unzip, edit, rezip, upload ? it was bad enough before…
On another note…today I exported a Kinetic layer from my Pilot/Test environment to my ERP/Production environment…it shows up in app studio landing page and menu maintenance, but when I launch it, it does not load, and when I launch it from app studio it loads the old version and when I do a ‘change version’ it’s not even listed !!!
You can open the ZIP and save the changes back into the ZIP. At least that’s what I do with 7-Zip but I think the built-in Windows one would do it too.
Where is Epicor on this? I guess that’s my question. What has happened and why are several people on this thread (and other threads on this site) now having issues?
I’m totally open to the fact that some of us may not have been downloading and uploading reports in the proper way (i.e. using the “design SSRS report” functionality to generate data and download/design the report), but is that what this is? Are we just doing it wrong?
It seems odd that all these people are having issues, but the reason is nameless.
Response from Epicor:
Issue is with a table getting records after copying/uploading the report, please upload the report you want to use and we’ll run a script to temporarily fix this, A permanent fix is bein created right now and it’s going to be applied for Live update so this doesn’t happen.
We expect to have the container build Tomorrow, so permanent fix can be applied this weekend, earlier next week.
We are web only, and we are currently in the state of if you upload any report, it will fail, regardless of the changes made to it
In addition it doesn’t matter if you upload via classic, smart client, web version. I’ve tested all 3 and they all fail to run when you upload them. The upload looks successful, however when you actually run them, you get errors.
Only the best functionality Epicor built in all of E10??
So you can have one app to download, preview changes, and publish, with no manual steps at all?
