Pilot and Live are completely different environments and changes in Pilot will need to be manually imported into Live for them to take effect - same as it is today.
Got it, so if I copy my database and restore it to another environment the rdls come along. But otherwise changes are deployed manually, environment by environment?
Correct.
@klincecum I will endeavour to me more sussinct in the future and avoid too much rambling… ![]()
@Rich
I have a few other questions.
I also saw the ice. Common database appear for 2023.2…Was that SSRS process fully working then?
If you were copying databases (e.g. To pilot SSRS) and you deleted the custom reports from SSRS on the destination (Pilot) server, on first run a custom RDL, it would be deployed to the SSRS server (Pilot)?
The use of ICE Common is gradually being expanded for static data / metadata. Version 2024.1 was the first version where SSRS RDLs are delivered via ICE Common.
If an SSRS report is run but the RDL does not yet exist in SSRS, the reporting framework will update SSRS with the appropriate RDL - custom or standard - based on the Report Style selected for the report execution.
I think this is the most underhyped improvement ever. This is going to be huge for cloud since its practically impossible to move rdls using solution workbench and none of the other workarounds to move reports in bulk are available for cloud.
I was gonna make you a tool, but now I don’t have to. ![]()
May I ask when the US Central DC can expect the update since it won’t be coming with the 2024.1.8 push to Production?
The corrected code for the SSRS issue was included in the Production Update to 2024.1.8 for all of the DCs that were updated this past weekend and it will also be included in the Production Upgrade to 2024.1.8 for US Central and Canada coming this weekend.
Wonderful! Thank you!
When will pilot be fixed?
@aosemwengie1 Seems we have two threads on this. I opened a support ticket yesterday as our UAT was failing due to not being able to print. They installed a hotfix to our environment within a few minutes.
Do you know if every single cloud customer has to individually request a hotfix? Or if there is a plan to just fix all the environments?
Not sure, I assume they will fix it for everyone this weekend but I couldn’t wait.
