Hi, Are there any way to add page number in page boy without Report Header and Report Footer in SSRS reports?
Ms. Lynn: I do not know of a way to get page numbers without a header or footer.
Maybe one of our guru’s knows a “trick” ?
DaveO
Would it be fair to ask… but why?
I like to enforce best practices and standards.
- Add it to the header and give a name to the textbox (by example txtPageNumber)
- Hide the header
- Add a text box in the body and change it’s expression for =ReportItems!txtPageNumber.Value
As others mentioned you’ll need the header at least.
Also, there are limits to what you can do with the page numbers…
- compared to Crystal which assigns numbers as each page is processed
- SSRS on the other hand, renders all the pages before assigning the page numbers.
Thank you for your reply.
After I did the following expression =ReportItems!txtPageNumber.Value in textbox . SSRS can’t be saved.
It shows error as Report item expressions can only refer to other report items within the same grouping scope or a containing grouping scope.
