We use Vantage payroll and have employees that will affect, but not this early in the year. We will use the solution Randy explained. I don't know why you couldn't have 2-3 tables out there with the different threshold amounts (one w/$200,000, one w/$250,000, and one w/$125,000 if needed) and point the appropriate tax table to each employee. The federal tax tables are set up that way with different tables for married and single, they work just fine. The medicare tax tables would only need two levels instead of the multiple levels the federal tax tables use.
Sue
Sue
--- In vantage@yahoogroups.com, Randy Lunsford wrote:
> Dina, I added a tax table and from 0 to $200k, it is 1.45%, $200k to $99,999,999.99, it is 2.35%. The only problem is the $200k is for single employees. The higher rate kicks in at $250,000 for married employees. I'm not sure how to handle that.
> We don't have anyone at that level, yet.
> [Description: Description: Description: cid:image001.jpg@...]Randall Lunsford
> Controller/IT
> Excel Machinery Ltd
> An Employee Owned Company
> 806-350-1531
> 800-858-4002
> Skype - Randall.Lunsford1
> rlunsf@...
> Have you seen our brand new website? www.excelmach.com
> [Description: Description: Description: Description: cid:image003.jpg@...]
> P Please join me in making a difference. Think before you print.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dina Hieber
> Sent: Monday, January 14, 2013 1:54 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] STILL NEED HELP - PAYROLL PROCESSING PROBLEM - DUE TODAY NEW MEDICARE GUIDELINES - HOW TO HANDLE IN VANTAGE 5.2
> Whats happening, it is looking at the pay amount, figuring the ee is going to make 200K+ and automatically calculating the higher percentage. But the EE only pays the higher tax on the 200K and above. Make sense?
> I thought I would actually get a lot of response on this, and how people are handling. From what I am seeing 9.0 handles the same way. I am guessing a lot of companies are not using Vantage payroll?
> Best Regards,
> Dina M. Hieber
> Vamco International, Inc.
> 555 Epsilon Drive
> Pittsburgh, PA 15238
> (412) 963-7100 x 203
> (412) 963-9511
> www.vamcointernational.comhttp://www.vamcointernational.com>
> This e-mail message and any files transmitted with it are confidential and are intended for the sole use of the intended receipient(s). Any unauthorized use or disclosure is prohibited. Any opinions express in the email are those of the individual and not necessarily the company. If you are not the intended recipient, please contact the send by reply email and destroy all copies of the original message.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com ] On Behalf Of Julie Lehmann
> Sent: Monday, January 14, 2013 2:27 PM
> Subject: Re: [Vantage] STILL NEED HELP - PAYROLL PROCESSING PROBLEM - DUE TODAY NEW MEDICARE GUIDELINES - HOW TO HANDLE IN VANTAGE 5.2
> Dina,
> Have her look at or try "Additional tax on Gross Wages" on the Medicare tax screen, by reading help - it sounds like it is worth trying.
> Julie Lehmann
> Mercury Minnesota Inc.
> From: Dina Hieber
> Sent: Monday, January 14, 2013 11:38 AM
> This is on the Medicare part, if the employee makes higher than 200,000 the Medicare portion is higher. We talked to Epicor, and their solution did not work either... Any ideas?
> Best Regards,
> Dina M. Hieber
> 555 Epsilon Drive
> (412) 963-9511
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com ] On Behalf Of Dina Hieber
> Sent: Monday, January 14, 2013 11:11 AM
> Subject: RE: [Vantage] HELP - PAYROLL PROCESSING PROBLEM - DUE TODAY NEW MEDICARE GUIDELINES - HOW TO HANDLE IN VANTAGE 5.2
> Thanks Julie. I will send her your #!
> Best Regards,
> Dina M. Hieber
> 555 Epsilon Drive
> (412) 963-9511
> Sent: Monday, January 14, 2013 10:54 AM
> Subject: Re: [Vantage] HELP - PAYROLL PROCESSING PROBLEM - DUE TODAY NEW MEDICARE GUIDELINES - HOW TO HANDLE IN VANTAGE 5.2
> Dina,
> We're on 6.1, but I'm assuming it's still very similiar - I updated mine with no problem, and it's working fine.
> If you'd like, she can call me & I'll help her through it.
> Julie Lehmann
> 507-332-1149
> From: Dina Hieber
> Sent: Monday, January 14, 2013 9:22 AM
> Subject: [Vantage] HELP - PAYROLL PROCESSING PROBLEM - DUE TODAY NEW MEDICARE GUIDELINES - HOW TO HANDLE IN VANTAGE 5.2
> We are doing the first pay for the year in Vantage 5.2. Our payroll department is not sure how to enter the new Medicare for the EE. She said she set up the tax as a table in Vantage. But she said it is not calculating it correctly. How did everyone else handle this? I am sure, she is not the first to ask this question. :) HELP - payroll is due today
> [cid:image001.jpg@... ]
> Best Regards,
> Dina M. Hieber
> 555 Epsilon Drive
> (412) 963-9511
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com ] On Behalf Of greg_clauser
> Sent: Monday, January 14, 2013 10:06 AM
> Subject: [Vantage] Re: E9 Maintenance Module
> I'm also just starting to implement but in a multi-plant environment.
> With Maintenance Operations having to reference Resources, the Equipment
> (location) resources are plant specific. However, the people resource of
> a 'Maintenance Crew' or 'Maintenance Tech A' in our case needs to be
> able to work in any of the plants where they happen to be needed that
> day.
> Support has no suggestions, anyone else run in to this?
> Greg
> --- In vantage@yahoogroups.com , Rob Bucek wrote:
> > I just purchased that module recently and am in the middle of
> implementing it. So far (and I had the first impressions you did) as
> usual the devil is in the details, and I'm Highly Underwhelmed at this
> point. There are two critical areas that were not very well thought out
> at all. The first is components, where you list individual
> parts/assemblies/or major subcomponents of a larger or main piece of
> equipment. Some genius thought it would be a good idea to design it so
> you had to tell the component its parent equipment ID, now you are hosed
> if this is a component that is common across more than one piece of
> equipment. Say you had a spindle drawbar on a vertical machining center
> used across several machine tools... you can only establish it under
> one! The other lackluster feature is in scheduling. In order for it to
> block out production time in the schedule when the machine is being used
> for preventative or reactive maintenance you have to tie the resource
> which is tied to the equipment ID directly to the maintenance operation.
> This sounds reasonable at first, but instead of the software just
> looking through the equipment ID on the job and the resource tied to the
> equipment ID in the set up, you now have to create an operation per
> piece of equipment. So if you have 70 pieces of equipment, you have to
> have 70 operations to cover this (and for each type of operation you may
> want). The really irritating this is, if you have say 3 production
> machines, they are all the same, you'll have to have 3 separate
> operations (all identical save for the different resources tied to
> them). In my mind this will be a nightmare for maintenance guys to keep
> straight... That's what I've found so far... Over all this is a pretty
> new module for them, and as a result is a bit more shallow than you'd
> think given the demos you probably saw.
> > Rob Bucek
> > Production Control Manager
> > PH: (715) 284-5376 ext 311
> > Mobile: (715)896-4832
> > FAX: (715)284-4084
> > [cid:1.234354861@]
> > (Click the logo to view our site)
> Behalf Of cesatlanta
> > Sent: Wednesday, December 05, 2012 9:29 AM
> > Subject: [Vantage] E9 Maintenance Module
> > We are considering the addition of the Maintenance module to schedule
> and track tooling and equipment maintenance. Of course we went through
> the Demo and it worked "seemlessly and flawlessly".
> > Does anybody have any experience with it, good or bad. Our other
> option is to get a third party solution and interface through service
> connect. Any opinions on this alternative are also welcome.
