Stocking Kanban
Hey all! We’re trying to set up stocking type kanban. We’re clearly missing something on the set up because we cannot get the system to recognize the low inventory and send us a signal that it needs to be filled. We’re using 2022.1.9 right now if that helps. I feel like we have the part set up right and maybe are just missing a replenishment setting but could be wrong. Any help you can provide I would greatly appreciate it.
stocking type for what? A manufactured material or a purchased material?
You should probably put screenshots of your settings for people to be able to help, but off hand one thing that can catch you - if its already below threshold it will never trigger. It has to be above and then fall below for it to trigger the replenishment.
Phase 1 is to use this on purchased items like Loctite. Eventually we want to use this on parts we make to stock. But we aren’t looking for automatic generation of jobs/PO’s, we just want to receive the notification that the Assembly bin on the floor needs another bottle from the main warehouse.
Ohhh that’s interesting. I will test that to see if that’s what we missed.
Okay, yeah on purchased materials I think you need to set up a PO so that it adds a release. And then when you go below your minimum / safety then it will generate a new release on the a PO/PO Line.
I made a function that will create a manual replenishment for this scenario. It runs hourly and looks for items that should have a replenishment queue that don’t and that we now have inventory to fulfill. If it finds one, it creates a manual request to put into the material queue.
Still very surprised by this behavior, seems like a huge oversight.
Nice catch Alisa, it’s been so long since I re-visited this functionality… I think we were a little hesitant to let go of our “generate po suggestions” routine and use the kanban functionality so we never did get into it fully.
This video by @timshuwy made things a lot clearer for me Back to Basics – Purchasing Kanban (Automatic)
We found it took a bit of time for the stock to settle into the correct pattern, mainly down to min/ max’s being set incorrectly and stock never going over the threshold.
The main thing to understand is to have enough stock been ordered to take you over the threshold bearing in mind the lead time.
If you’ve ordered 50 units and in the time it takes to arrive you’ve used 60, you will have problems.
Once you’ve got it running correctly it works fine.
Thanks for sharing that Andrew, they did a presentation at insights a few years back too that was really nice, glad they did another webinar on it too!
