Might I suggest that you populate all of the records with Date01
(because it will be there later in case you think of a good reason). And
then set checkbox 2 as needed (such as if you have an entry in the
trading partner field). Using an existing field rather as a kickoff to
the checkbox rather than hard coding the Customer would give you better
flexibility down the road. If you have only one customer with a trading
partner ID, you have still accomplished the same goal.
Of Matt Caldwell
Sent: Thursday, June 04, 2009 8:34 AM
Subject: RE: [Vantage] Stuck on a BPM
Checkbox02 is a flag that tells us that the Invoice should be invoiced
via EDI. And the Date is there as another criteria for that same
reason. We built an application that at a specific time of the
afternoon, scans InvcHead for any invoice that has Checkbox02 set to
true, and a Date01 equal to todays date. Then that app will grab all
of the necessary data to build our EDI files that we upload to our VAN.
Behalf
Of CharlieSmith
Sent: Wednesday, June 03, 2009 10:52 PM
What do you want to do with the rest of the invoices? Leave the date and
checkbox empty and false? What is the purpose of these actions?
Behalf
Of Matt Caldwell
Sent: Wednesday, June 03, 2009 5:55 PM
Subject: [Vantage] Stuck on a BPM
I am fairly new at BPMs, and I am stuck. Here is what I want. After you
create a group in Invoice Entry and bring in the shipments, I want a BPM
that will check the CustNum of each of the shipments. If any of them
equal a specific customer, I want to automatically enter today's date in
InvcHead.date01, and set InvcHead.checkbox02 to true. I cannot seem to
capture the correct Business Object. Can someone give me a nudge in the
right direction?
Matt Caldwell
Of Matt Caldwell
Behalf
Of CharlieSmith
Behalf
Of Matt Caldwell
right direction?
Matt Caldwell
