I am moving BAQs over from E9 to E10, and this is the logic for the E9 calculated field I’m trying to duplicate.
(integer(ShipHead.ShipDate) - integer(OrderRel.ReqDate))
When I use that exactly in E10, I get the error 'integer is not a recognized built-in function name.
I already tried simply exporting the BAQ and importing it in E10, it worked for most, but this one said ‘Bad SQL Statement’ so I am rebuilding it. If you have another suggestion that would help also.
Logan
