Hoping someone can help me out here. I have created seven new parts, all manufactured and all with a revision (approved) and a BOm containing one material and three operations (one of which is subcontract). I have entered a safety stock for them all. Run MRP is checked.
I was expecting MRP to create jobs to satisfy the safety stock, but it hasn’t. Instead I am getting this for all the parts in Time Phase;
I am sure there are other reasons Epicor will create a job suggestion instead of an unfirm job but the only one that I am aware of is no approved revision.
I wouldn’t expect demand from safety stock to behave differently than any other type of demand but maybe that has something to do with it. These are all inventoried/quantity bearing parts?
What happens if you try and create a quick job for one of these parts?
At THIS point I’m sort if in bug-search mode… if you put the value you have in Safety Stock in Minimum On-Hand Qty, does that make MRP create the job? I’m wondering if there is a bug that makes it ignore Safety Stock if there is a zero Min OH.
I saw this before when I had parts with approved alternate methods in a site that made suggestions. I had to set the alternate method under Parts / Planning for MRP to make the job.
Run MRP for just one of the parts, (which will be a Net Change run) and set logging to Verbose. Use Server File Download (if in cloud) and review the logs, they usually tell what happened each step of the MRP run. I find a lot of the “Why’s” there.
